Any user reviews on GT2554 out there
   / Any user reviews on GT2554 out there #1
KBEAT
Bronze Member
Hey guys, I currently have an CC LT1050 and an Ingersoll 4016 that I use to cut the grass around the house (About 2 or 3 acres with a walkout basement and quite a bit of slope). I use the CC to make a few passes around the yard and cut around the trees because it handles much better than the Ingersoll, then switch over. I have heard of issues with the 1000 series transmissions and worry about using it on the slope for the walkout, so I was looking to trade up. I found a newer, very low hour GT2554 I was looking at, the transmission seems better suited to what I use it for. In looking at online reviews there were alot of complaints about the hood brackets breaking, the deck wheels falling off and engines backfiring. Not sure if these are real/current issues or just a vocal minority. Any current or past owners out there with any feedback ?
   / Any user reviews on GT2554 out there #2
Hi, we have a 2550 which is the same tractor only diff is the 50" deck. That tractor your considering has a drive shaft as opposed to a belt drive so it will handle the slopes. As far as the other issues yes I've heard the stories but none of them were real show stoppers.
There's 2 screws under the hood against the fire wall, kind of hard to see unless you squat and look for them...they need periodic tightening. Always hand guide the hood up and down. I've had a few minor issues but they all had work-arounds. If the price is right I'd get it...my 2 cents.
just say'en....it seems to me the Ingersoll 4016 is also up to the job.
   / Any user reviews on GT2554 out there #3
Have a Gt2550 , upgraded from a HDS2155 , so far no problems runs and cuts well.
The major problems I read appear to be the early model Gt2550 and they all appear to have been fixed during the model run.
Any early model may have experienced those problems and should have now been overcome.
Saveageactor7, you're right, the Ingersoll 4016 is up to the job. It's a great machine except for turning radius. I use the Cub on the border and around all the trees, then out comes "The Beast". It runs, rides and cuts great, just lacking in handling :)
   / Any user reviews on GT2554 out there #6
I' on my 3rd season with my GT2550 and I have no complaints. If it was built after 2008, I think the deck was redesigned to have a wider discharge chute. Mine never clogs and rarely leaves a clump. I too had a LT1042 before and there is no comparison. The 2500 series has a much heavier drive train and really puts the power to the ground.
   / Any user reviews on GT2554 out there #7
I have an old cub cadet 1806,sturdy as **** and a3 year old gt2554 where there is always something breaking! wheel falling off, hood melting,
oil cap stripping off, headlight wires coming apart and this with 200 hrs on the clock. I do not recommend...
25077 (A51694)
25077 (A51694)
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2018 Altec DC1317 Towable Brush Chipper (A55851)
2018 Altec DC1317...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
2023 Kubota L2502DT (A53317)
2023 Kubota...
