any suggestions where to look?
   / any suggestions where to look? #1
rollbar
Bronze Member
2005 4520 jd
I own a 4520 jd less than two years old. I had a fuel sender replaced and about two months later I turned on the head lights ,which I had not used since having the fuesender replaced,the flashers come on but the headlights do not. before I take it back to the dealer any suggestions where to look first to check for a loose wire or bad switch? thanks for any help
   / any suggestions where to look? #2
I'd first check the headlight connector under the hood. It's possible that it came disconnected or was disconnected by accident when the fuel sender work was done. It's right up front under the hood behind the lights.
1999 JCB 926 (A53314)
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2008 CASE 721E Wheel Loader (A47477)
2008 CASE 721E...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2017 Nissam NV200 Cargo Van (A55788)
2017 Nissam NV200...
