I'm pretty used to setting the lever that holds the clutch open in the winter, but typically it hasn't been necessary here in our dry summers. Well we got 6" of rain last month and may be close to that this month at the rate we are going. And when I went to use the tractor today, I found the clutch plate stuck to the flywheel. The usual trick of running it against an immovable object didn't work to pop the clutch plate free. I even tried putting the front bucket up against 15T of dirt that I just brought in, and it did was spin the tires and dig holes.
I was wondering if there are any more tricks to try before I bite the bullet and open it up to look at/replace the clutch? Perhaps trying this same trick in a higher gear might be more effective? Anything else?
TIA
TIA
