Snowblower Any snowblower recommendations for Kubota L4400
   / Any snowblower recommendations for Kubota L4400 #1
PVHunter
Michigan
Ferguson T20;Kubota L4400
My dad and I recently purchased an Kubota L4400 with Ag tires. I was wondering if anyone had a recommendation for a rear 3pt snowblower for this model. Width between the wheels is about 65" or so. A local dealer quoted a Woods SS74 for $3250. I was hoping it would come in around 2k or so. Maybe this is unrealistic for a new model. We have approximately a half mile to snowblow - two very long sand/gravel driveways in Central Michigan. Thanks.
   / Any snowblower recommendations for Kubota L4400 #2
That seems a bit high for a basic 3pt blower, especially in snow country. You should be able to get something like a 72" Pronovost Puma for $2500 or so. I am sure there are several other manufacturer models out there in the same price range. As an example, my 64" Puma was only $1800. You then have to add another $200 for hydraulic chute roataion and $100 for hydraulic chute deflection.
   / Any snowblower recommendations for Kubota L4400 #3
If you look for a Puma better look for the 74" model or larger. The max. recommended HP for the Puma-72 is 25HP. With 37 PTO HP, your L4400 might give the 72 more twist than it could take. The Puma-74 is rated for up to 40HP, the 84 will handle more yet.
Hope your lowest reverse gear is slow enough for a blower when turning 540 PTO RPM. My L4300 with only two reverse gears is way too fast.
Bob
2005 KENWORTH T800 (A52472)
2005 KENWORTH T800...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
377811 (A48836)
377811 (A48836)
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
