Any one using the sicle bar mower?
   / Any one using the sicle bar mower? #1
tmarch
Bronze Member
pine ridge of Nebraska
Looking at getting the sicle bar mower from Skid Steer Solutions and interested in any information from current users. I have some roads to mow and some grass that would make hay, so those would be the main uses along with maintaining my 5 acre outter yard.
THANKS!!!
   / Any one using the sicle bar mower? #2
Looks like a way-cool attachment; however, on their webpage for this product they print, "Plug and play available for Bobcat 14 pin, John Deere 14 pin, New Holland 14 pin, ASV and Cat 8 Pin electrical connectors."
I'm thinking that unless you have a older 14-pin interface, you won't be pluggin-and-playin. My TC "D" only has the 7-pin CAN bus electrical interface out on the boom. The 14-pin and 7-pin electrical interfaces are fundamentally different and their is no "bridging" technology (converter) available AFAIK. Some TC's have both 7-pin and 14-pin interfaces. I believe Rip (frequent poster around these parts) has a TC configured as such.
Even if you don't have a 14-pin interface, fabricating your own controller should be pretty easy...or you can buy one from some place like Quick-Attach/Erskine and wire it in.
Good luck and let us know how it works. I've been thinking how great such an attachment would be.
Kevin
   / Any one using the sicle bar mower? #4
PaulChristenson said:
Skid Steer Sickle Bar Mower
$7K is not the cheapest solution around...:D
Based on the pictures, the front visibility is about zero. I hope the sickle bar is designed to brakeaway. Hit any obstacle with the sickle and it is either bent or broke.
Maybe I need to clarify a few things, I don't have a tractor, state law says I have to mow the sides of the public road that borders my land & I do have livestock so can use the hay.
A brush cutter may handle the tall grass, but a finish mower won't and I'm wasting the hay which I have buy at $100 a ton or more.
   / Any one using the sicle bar mower? #6
If you want to use a financial argument to justify the purchase of a sickle bar mower for $7000 so you can recoup the grass cuttings, I hope you have a lot of roadside to mow!
OK, roughly 43264 square feet per acre, and roadside should yield about 1 ton per acre, unless you are cultivating / fertilizing the roadside also. Let's use the 1 ton /acre, you can adjust if you think it's warranted.
An 8 foot swath of roadside would need to extend 5408 feet to equal an acre, close to 1 mile. So, 1 ton of grass / hay per mile of roadside. $100 value to the hay, $7000 for the mower, plus fuel, wear & tear on the Toolcat, repairs, etc. You need to mow 700 miles of roadside to cover the mower attachment cost alone.
Now, if you have to mow it anyway, and need to buy SOMETHING to mow it, some of that cost is sunk (you gotta do something) so if the incremental cost of buying this particular mower attachment isn't too much more than the cost of the minimal mower you need to do the same job, maybe it makes sense.
Personally, if I had the money I'd buy it just because it's cool! I would love to chase down a neighbor with that sickle bar running at full speed next time I catch him throwing rocks at the horses...
Rich
   / Any one using the sicle bar mower? #7
Wow...in VT we have state contracts to mow the highway sides...and the mowers know which swales to leave...because some farmers will bale right to the road...:D
   / Any one using the sicle bar mower? #8
Sickle mower will not do well with any trash in the ditch or trees. Even small trees with break the sickle sections. I have mowed roadsides with tractor mounted sickle mowers. I just mow the road edge where there are no trees and little to no trash and leave the sickle raised up slighly. Depending on the roadside, there maybe more weeds than grass. I now use a batwing mower and I can do a much better job and it will mow down the trees, brush etc. I still don't mow the entire ditch, it is just too much hassel and ditches are too steep and rough where I live.
The law on mowing roadsides in NE may exist but who enforce it? I didn't know such a law existed but lots of stuff I don't know. I travel around rural NE a lot and don't see many mowed raodsides except highways. The state mows the highway areas and the gravel roads get little to no mowing.
Most and I mean most of the roads here in extreme NW Nebraska are mowed, as far as this year I'll probably hire a neighbor or someone unless the county gets on me.
The way this thing works it looks like I could mow with good visbility and keep the cutter bar above the rocks and there isn't any trees that should pose a problem.
I was hopeing someone had 1 to get a report as to reliabilty and service, but it is a relatively new item so not many in use I suppose.
   / Any one using the sicle bar mower? #10
tmarch,
I own one of the sickle mowers from Skid Steer Solutions. We are located in Washington State and use it mostly in a near vertical position to mow the edges of horse riding paths. We've owned it since 2005 and have been very happy with its operation. I have broken my share of sickle teeth and guard sections, but they are not very expensive to replace and they were broken from fairly abusive mowing where I was cutting branches up to about 1.5" in diameter. The sickle bar cutter portion of the unit is made by Kosch (Kosch Company), and I buy all of my spare parts directly from them at very reasonable prices. The unit does have a breakaway system to protect the sickle, but be aware that the breakaway doesn't work very well when the unit is in a near vertical position. I bent the bar once catching it on a tree but was able to straighten it out.
MGT Towable Cement Mixer (A44571)
MGT Towable Cement...
2014 WESTERN STAR 4900 TRI AXLE (A45046)
2014 WESTERN STAR...
2013 JLG SKYTRAK 10054 TELEHANDLER(INOPERABLE) (A45046)
2013 JLG SKYTRAK...
Exhaust Cover (A44502)
2017 Chevrolet Malibu (A44501)
2017 Chevrolet...
10 WROUGHT IRON FENCE (A45046)
10 WROUGHT IRON...
