Any one try a cordless electric pole saw?
   / Any one try a cordless electric pole saw? #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I'm not sure I can justify the nice Stihl I saw on their website (about 700 bucks).
I need to clear the occasional 2"-3" limb in spots so as not to damage my cab. The lights on the sunshade on my current tractor have taking a bit of a beating.
I can either rent a pole saw once a year (about $70 per day) or buy one of the Black and Decker cordless ones that people rave about ($150 or so). In online reviews people are saying they are cutting 5 to 6" stuff with it.
What do you guys think?
   / Any one try a cordless electric pole saw? #2
Why don't you buy a manual saw.Mine goes to 14ft.real Sharpe ,works well.I tried the $200.00 Poulan..waste of money,junk from the word go.Going to be limited with an electric.
   / Any one try a cordless electric pole saw? #3
I have no experience and therefore no idea whether the Homelite electric pole saw is really any good or not, but back in May when a little storm tore down a tree in my yard, I bought a cheap Homelite electric chain saw at Home Depot and was very pleasantly surprised at how well it worked. Later a friend had a storm blow down a tree in his yard and we used my little Homelite to cut it up. Black & Decker may be better, but in your situation, I'd have to go to Home Depot and give that Homelite a try. In fact, I'm considering buying one myself for tree pruning.:)
   / Any one try a cordless electric pole saw? #4
I have a Remington battery pole saw. It lasts for about 3 cuts of 3-4 inch diameter, sometimes a little shy of that.
If you do not need quick results it works fine. If you have alot to do, you will be frustrated with it.
   / Any one try a cordless electric pole saw? #5
   / Any one try a cordless electric pole saw? #6
J J, I don't have a battery powered sawzall, but do have a corded Makita reciprocating saw and I was doing all my tree pruning with that and pruning blades; even cut up one tree that blew down. It was interesting cutting the stump because the blade was only about half as long as the diameter of the stump, so I went around and around until I cut it off. But the electric chain saw sure is faster and easier.
   / Any one try a cordless electric pole saw? #7
I have a HD 25 foot telescoping pole.....and I have a 18volt battery powered sawzall. I needed to limb a tree, so I duct taped the saw to the pole and put a 12inch wood-cutting blade in the saw.
It can get a little dicey handleing a saw which has the switch on the biz end of the pole.....but I got my limbs cut off. (tree limbs that is) :thumbsup:
I felt a bit like a red-neck....but worked pretty good. :laughing:
   / Any one try a cordless electric pole saw? #8
I sold the B&D polesaw, in a previous job. Link below lists my comments on the 18v B&D grass trimmer, included here to pass along 411 about the batteries and how to work with them the best.
The B&D polesaw is a good design, they use the same setup for their 18v chainsaw. As I explained to customers, "If you're looking at a 4' oak tree, this chainsaw ain't the right tool" - most people got that, and saw where it would be useful - even pro arbourists.
The pole extensions are well made, strong, and the connector system never seemed to be a problem. About the only issue that came up sometimes was that the chain was installed backwards (I just showed people how to keep the arrows aligned, bar/chain), hardly the fault of the saw.
For most people, I think these 18v polesaws are a good solution.
http://www.tractorbynet.com/forums/garden-tools/63542-trimmer-built-women-3.html
D.
   / Any one try a cordless electric pole saw? #10
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
19015 (A53422)
19015 (A53422)
2016 Ford F-450 12ft Flatbed Truck (A55852)
2016 Ford F-450...
2010 NORMA G20 GENERATOR (A55745)
2010 NORMA G20...
