Any Mitsubish owners here??
   / Any Mitsubish owners here?? #1
Dreadnought
Yanmar F22D/Mitsubishi MT28
Just bought a Mitsubishi MTX28D MAC in very good condition 1400 hrs...........But I need an owners manual, this one came used from Japan and came without a handbook. I need to know things like how do I tell if it has enough Hydraulic oil....no dipstick visible.....what OIL ?? My other tractor Yanmar F22D uses ATF. THis Mitsubishi is only 5 HP more than my Yanmar but seems to be in another league, they Yanmar Punched well above it's weight.
   / Any Mitsubish owners here?? #2
As a former Mitsubishi owner I'm not sure how much help I can be. I had a D2350 and got my manual from Valley Power. If you had the original manual it would probably be in Japanese. The people at Valley Tractor can provide manuals for some models in English. On my tractor the standard transmission shared the same oil bath as the hydraulic system. A combination tractor oil was best for that system. If you have a hydrostatic transmission you could use a different fluid. The fill was on top of the transmission. You could pull a rubber plug on the side to check the level. If you plug mitsubishi mtx28d into your search engine you will get more information.
Thanks, roadworthy, very fast reply.....I will write to Valley Power. I suspect my MTX28D is/was called something else in USA (I,m an Englishman living in Eastern Poland) But looking at the Valley Power site they will be able to match me up with a manual that will be close enough. I will look for that rubber Bung, I notice there is a big Rubber bung on the front-drive axle casing. So maybe I am looking for something similar. So maybe I need to look again, the main transmission case has a plastic screw-in filler plug on top of the transmission, right at the back above the 3 point linkage.
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
2015 Hitachi PC138 (A47477)
2015 Hitachi PC138...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A55788)
2011 Mack GU713...
