Any JD4700 owners here??
   / Any JD4700 owners here?? #1
al20hp
Jd 4700
Just bought a JD 4700. About 10 years old. Just curious if there are Any 4700 owners on this forum. If so any advice with this unit????
Al
Bump bump bump
   / Any JD4700 owners here?? #4
Yes I have one. I have almost 2750 Hours on it and it still runs like a charm. Its a daily runner in the spring till early fall. We use it as a box hauler. Hauling about 0-700 boxes per wagon maximum weight i think it ever hauled was like 5000lbs. 30% rubber left on it. Power Reverser Transmission. We had 2 Problems with it. The front axle started leaking fluid at 2000 Hours replaced for around 4000. And a new starter that's all. These tractors are easy to maintain, strong, and pretty much you would expect from John Deere excect the axle problem.. We have some drivers that drive like A**h***s. If were not using this tractor we would be using our 5420 or our 5085M to do this job. Overall this tractor is very strong. But it will be needed to be ballasted if hauling heavy or loader work.
Ed
So far everything seems to be ok with it. Only a very few minor things. I too have the power reverser model. I think I am going to take it to the local jd dealer and have them change the funds etc.... I have the 460 loader and the jd 48 backhoe. The tires are ca filled. For the size of this machine it seems like it has good power.
Do you use the 4wd on yours ?
I am wondering if that contributed to the axle failure.
Al
   / Any JD4700 owners here?? #6
Yes we do use 4WD we have some workers that drive with 4WD on the road so it might of happened from there. Which is pretty hard on the axle.
   / Any JD4700 owners here?? #8
Ed
...... I think I am going to take it to the local jd dealer and have them change the funds etc.... ............Al
What would that be?
That was a typo. I wanted to say" take it to the dealer to change the fluids". However, after reading Chucks post with the info on how to change the gear oil, axles, fuel filter. I think I will do it myself.
Thanks.
Al
   / Any JD4700 owners here?? #10
I have had one now for about 3 years and have put about 200 hours a year on it. It is a power reverser model and I have had 0 problems with it. I keep all the fluids and filters changed and use it. Below are some pictures of it doing different jobs. I use on a 10 ft wheel disk, 10ft field cultivator, sprayer and a 2 bottom plow mostly. I also do a little snow removal in the winter with it.
John Deere 960 Culitivator (A50514)
John Deere 960...
2013 VOLVO VNM DAY CAB (A51222)
2013 VOLVO VNM DAY...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
JLG 1255 Telehandler (A51039)
JLG 1255...
2007 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2007 STERLING...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
