Any ideas on how to fix?.
   / Any ideas on how to fix?. #1
BuzzardA91
West Granby CT
JD 4105. 375 Backhoe. 2005 Polaris Ranger
I purchased a used Curtiss snow plow with the JDQA. It was used for a year on a JD 3320. Very similar to my 4105. When I went to Put it on the bottom pins on the JDQA don't quite fit in the holes of the FEL. One side I can get to drop in but the other is just ever so slightly off. I sandpapered the paint off and greased the pins but still won't go on. The plow is like new, no bends, damage, rust or anything. What do you all think would be the best way to fix it? Maybe tap one pin with a sledge? A grinder would do a number on the pin and would make a mess. If the pin could be removed and turned down a touch that would work but they are welded in. Help.
   / Any ideas on how to fix?. #2
Adjust ever so slightly with a 16 pound sledge hammer and block of wood
   / Any ideas on how to fix?. #3
I would also adjust it with a sledge hammmer, maybe a 10lb though. Are you sure the pins are welded on. On all of my attachments they are threaded with a nut on the other side. Of course I don't have any experience with snow plows. :)
Yeah, welded on. I just checked. I'm also thinking because the way the plow is balanced (heavy forward weight) it doesn't attach as "forgiving" as the bucket or forks do.
RoMad, you don't need a plow down there in Lecanto? :sunrise::fiery:
Thanks. If there aren't any other suggestions I will give it the sledgehammer route. I will be sure to report back. I am sure I am not the only one who has had this happen. There isn't much room for error with those pins.
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
AC CHARGING MACHINE (A50854)
AC CHARGING...
