Any Ideas for Quick disconnect for tractor light
   / Any Ideas for Quick disconnect for tractor light #1
Dale1995
Caribou,Maine
John Deere 2320
I am in the process of adding strobe lights on my 2320 John Deere for winter time use only, I have been trying to figure out a way to make the lights easy to disconnect when I am not using them in the off season, they are held on magnetically, I was thinking of using a trailer wiring connector as a quick disconnect, or maybe even some type of input jack like used on headphones. I want to mount this onto my Curtis cab for a neat appearance. Any ideas on different ways to do this, or am I barking up the wrong tree? Does anybody have any better solutions...I am open to suggestions. Thanks for your input....Buy the way they are forcasting 2 to 3 inches of snow here tomorrow night (Northern Maine) Don' you just love it!
   / Any Ideas for Quick disconnect for tractor light #2
Will the plug in the cab or outside in the elements?
I would like the female end of the plug to be on the outside of the cab if possible. My tractor is always inside.....it just goes outside to play in the snow:)
   / Any Ideas for Quick disconnect for tractor light #4
You might try a trailer plug,,they are made for outside use..and can be bought anywhere!!!
   / Any Ideas for Quick disconnect for tractor light #5
*** I was thinking of using a trailer wiring connector as a quick disconnect, or maybe even some type of input jack like used on headphones.
**Buy the way they are forcasting 2 to 3 inches of snow here tomorrow night (Northern Maine)
Don'tyou just love it!
***Either one should work. The trailer connector would be a little easier to put together but the input jack would probably be neater.
**No
   / Any Ideas for Quick disconnect for tractor light #6
Trailer plug would be my idea also. 4 prong would work just fine.
   / Any Ideas for Quick disconnect for tractor light #7
Do you have a cigarette lighter adapter on your tractor or can one be added. I am adding a strobe light on my tractor and have a cab with the 12v outlet. I know someone make the outlet kit for 4-wheelers. Might be something to look into.
   / Any Ideas for Quick disconnect for tractor light #8
Do you have a Marine supply store close? They have lots of good weatherproof connectors.
West Marine
   / Any Ideas for Quick disconnect for tractor light #9
You can use a two wire trailer connector -- it will be weatherproof , easy to connect/disconnect and they are available in up to 10 guage wire (and they are cheap :D) -- or you can use a lighter socket strategically placed and use it to power other things (like a coffee maker, hand held spot lamp or your iPod :eek:)
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
Post Hole Digger Auger (A50774)
Post Hole Digger...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
