Any hydraulics experts?
   / Any hydraulics experts? #1
busa20
I am replacing a diesel engine with a gas engine so I need a belt driven Power Steering pump in place of a gear driven pump. But the pumps I am finding are 3.5 GPM at 1200 PSI and I need 4 GPM at 2200 PSI. I have a pump on the Allison MT 643 transmission that is 20 GPM at 2200 PSI. Is there a valve to reduce the 20 GPM to 4 with the same PSI? The 20 GPM pump has # 12 lines coming off to feed a control valve, if I Tee off with a #4 or #6 line to feed the steering box would that do it, or do I need some kind of flow control valve? before you ask these Trans pumps come with Hyd oil OR ATF that run two 5" cylinders.
   / Any hydraulics experts? #2
   / Any hydraulics experts? #3
You are forgetting about RPM. There is no such thing as a "20 gpm" pump, but there are 20gpm @ 2000rpm pumps. If you only need 4gpm the best thing to do is reduce the pump speed by ~1/4. (as pumps slow down the internal leakage gets worse, don't go to 1/5th) You can use flow control devices, but they add $$ and parasitic losses.
ISZ
40' shipping container (A52377)
40' shipping...
2022 John Deere HD50F Draper Head (A53342)
2022 John Deere...
KUHN GMD-310-HD LOT NUMBER 37 (A53084)
KUHN GMD-310-HD...
John Deere GR72B (A50123)
John Deere GR72B...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
