Any hydraulic oil exports on here
   / Any hydraulic oil exports on here #1
tractorcrazy
Tractor dealers always say you have to use our brand oil for transmission. Kubota for instance says you have to use there DTU oil in there transmission is it really different from the normal trans/hydraulic oil
   / Any hydraulic oil exports on here #2
Kubota udt I use mobilfliud 424 , Kubota sudt2 I use that only....
   / Any hydraulic oil exports on here #3
Some Things to look for in hydraulic fluid are:
Does the fluid you are considering meet the specifications of the fluid specified for your machine? Example for wet brakes or clutches.
Weight or viscosity: this is usually more of a concern when running in hot 100 + degrees or cold ambient temperatures. What works in southern Texas may not work in northern Minnesota.
Usually far more important to keep it and water free vs brand of oil used.
   / Any hydraulic oil exports on here #4
Hydraulic oil likely has very few additives. It's just highly refined, about 20w by engine oil specs, oil with additives tailored for the type seals and those wet brakes that most tractors have. Best to go with what they recommend. I'm stretching the 200 hour changeout on the JD to 400 hours. I think 200 hours is really too short. That's only 5-7,000 miles figuring 25-35 mph equivalent. It's like their every other year coolant change recommendations. Waaaayyy out of line with standard practice now in our cars, trucks and SUVs. Stuck back in the 1980s.
Ralph
   / Any hydraulic oil exports on here #5
You need to stick with the same spec., not necessarily the brand
Machinery Lubrication
   / Any hydraulic oil exports on here #6
"Hydraulic oil likely has very few additives. It's just highly refined, about 20w by engine oil specs, oil with additives tailored for the type seals and those wet brakes that most tractors have......"
Industrial hydraulic oil yes, but "universal tractor oil" has a lot of additives in it. Viscosity and friction modifiers, additives to handle water/prevent rust, extreme pressure additives for the final drive, etc. It is false economy to use cheap oil in tractor and hydrostatic transmissions. Like ddbackhoe says - you can change brands but stick with the same spec. ISZ
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2021 JOHN DEERE CP690 LOT IDENTIFIER 182 (A53084)
2021 JOHN DEERE...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
UNUSED FUTURE 14' BI-PARTING WROUGHT IRON GATE (A51248)
UNUSED FUTURE 14'...
