Any HVAC guys out there?
   / Any HVAC guys out there? #1
Podunkadunk
Veteran Member
The external portion of my air conditioning unit (compressor??/fan) is humming. There are two of them out there, one for upstairs, the other for downstairs. The downstairs unit is making a hum. I've tried to listen to see where it's coming from, but can't tell.
It's pretty pronounced. It's been doing it for a while now. I first noticed it about 6 months ago.
Everything is working fine with the heater/AC...is this something I need to be concerned with?
Podunk
   / Any HVAC guys out there? #2
Only when unit is running? Without hearing/seeing it I would say contactor.
Bill,
It only "hums" when the unit isn't running, ie. it's between cycles. As I stated before, the heating/cooling works like a champ, it just hums.
I noticed it 6 months ago when cleaning out gutters. Then yesterday again while I was recaulking some windows by the unit.
Podunk
   / Any HVAC guys out there? #4
Podunk
I not a service guy, but sometimes, mine humms at the end of the cycle, nothing else is running, just a hum. My service guy said it was defrosting.
As stated before, I would get it checked, a friend of mine had his house catch fire and burnt up completely, from a faulty a/c unit. (house and unit was only 2 years old)
   / Any HVAC guys out there? #5
heat mode or cool mode ??
Kenmac,
Cool mode. We have the thermostat set at 77 and it's been pretty cool out, so the air cond. hasn't been running much.
I was around there today, it was humming and didn't kick on once (in the 60's and low 70's today so it didn't get low enough to cycle on).
Podunk
   / Any HVAC guys out there? #7
If there is a transformer on the outside unit ,that could be what your are hearing. I have seen people put a transformer at the outside unit. If not it could be the contractor. If it were in heat mode ,I would say defrost mode. You can cut the power & pull the side panel off where the electrical stuff is located. Turn the power back on & listen for the hum
   / Any HVAC guys out there? #8
Edit, never mind. Trying to trouble shoot over the internet is worse than doing it over the phone.
Contactor or transformer.
   / Any HVAC guys out there? #9
If its a heat pump, from what you describe (in cool mode, not running and hum), sounds like what you are hearing is the coil on your reversing valve. On everyone I ever worked on, its energized in cool mode and deenergized in heat mode (except when defrosting).
   / Any HVAC guys out there? #10
That's the other item that I forgot to mention
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
NISSAN 60 MAST FORKLIFT (A55745)
NISSAN 60 MAST...
Toro Zero Turn (A50324)
Toro Zero Turn...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
LOT LOCATIONS (A56129)
