any corn/biomass stove users
   / any corn/biomass stove users #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i'm looking at those corn stoves as a 2nd heat source for my home, i currently have an oil burning furnace w/ radiant baseboard heat, which is getting very expensive to run, i will still need the oil for my domestic hot water and baseboards. i was thinking of the corn/biomass stove as a 2nd source of heat to try to cut down on my oil use. i have an old 1930 farm house(1800sqft) which is well insulated, if i get the stove i was planning on putting it on the 1st floor and venting it to the outside as i only have 1 chimney flue. i was wondering if this would be a sensible place for the stove, as the heat rises i figure it would heat the 2nd floor as well.another ? i have is approxmately how much corn would you burn in a typical burning season later oct thru april? getting the corn isn't a big issue as there is a farm near me that sells it, and some others that are within a short drive. i did some work for a guy who had a biomass stove and he said he went through about 2 tons of corn and about 1 ton of pellets as he mixed them together. any thoughts would be very appreciated, jim
   / any corn/biomass stove users #2
I think that these stoves vent through the wall, no chimney is needed. Someone that knows for sure will hopefully chime in.
   / any corn/biomass stove users #3
Do a search--either this or the related forum had a very long thread on this subject within the past year, maybe even 6 months. I keep reading everything I see as I intend to switch from wood next year, but need to get a generator set up first, as the pellet/corn stove must have electricity to operate.
   / any corn/biomass stove users #4
As LMTC said, they need power to operate. I had a Englander pellet stove a few years back that i could mix 50/50 with pellets and corn.
It worked O.k. I guess but I live on top of a snowy mountain and the power outages are frequent so the stove didn't really work for me. You can power vent them straight out the wall, which is how 99% of owners do it. I personally like my wood stove ALOT better. No power is needed and it heats a whole lot better than the pellet stove. Even in adjacent rooms. and in my case all the wood is free.
I will just give you the pros and cons of my pellet/corn stove.
PROS:
* Less mess then with wood or coal.
* can fill hopper and know exactly how long it will burn.
* No need for a chimney
* Shuts off automatically when empty ( but then again all stoves will do that)
* Neat appearance
CONS:
* Needs power to operate
* You are at the mercy of corn and especially pellet prices. Which went up from $1.50 a bag to $3.25 a bag in the 3 years I owned one !! at around $4.50 a bag now
* Not a whole lot of radiant heat. Will heat one lagre room well but not others.
* cleaning the ash pot can get messy
* Corn only models are still PRICEY !!!
Hope this helps you out. But, as with everything like this, some things just work better for other people because no two situations are the same.
   / any corn/biomass stove users #5
Get yourself a battery backup for a sump pump or a larger computer UPS and use it to power the thing in the event of a power outage.
   / any corn/biomass stove users #6
I switched to a Pellett stove from woodstove last Febuary. Here are some of the thoughts that went into my decisions.
My wood supply was free, but that would not last forever on my small property other than the occasional blowdown. It certainly was not going to be enough to meet all my needs in the future. Once you factor in the price and time to process it, there is a cost to "free' wood anyway. If you are buying wood, in addition to the cash, it still costs you a bit of time to process it(stack in woodshed, split to size). I figured if I was going to buy wood, I might as well purchase wood that was already processed. Moves easilly, no real mess in the house, no bugs, ect... Factoring in all things, including the extra electricity, I think I am about even using pellets without the physical effort of processing the wood.
The pellet heats pretty well, but it isn't the deep radiant heat that the woodstove gave. There is also the noise to consider. These stoves typically have 2 blowers and a auger motor. Some are quieter than others so this is an important point to look at when deciding.
Power was also a concern. Woodstove didn't need it so power failures were never a big issue to me other than keeping the food cold. Typical pellet stove uses about 450 Watts under normal operation(700-900 watts during automatic startup). That would require a VERY large UPS to run any length of time. I have a 500VA(watt) UPS on my woodstove and it is only good for about 5 minutes of normal runtime. Enough to carry over and protect the controller from a small power hit or give me enough time to perform a normal shutdown if the power goes out completely. Also most modern UPS's won't startup unless they have valid 120VAC input power, even if their batteries are fully charged, so comming home to a dark cold house and starting up the pellett on the UPS is not an option. A better option might be an inverter, but that way also has issues. 450 Watts is a current draw of 3.75 amps at 120VAC. Using a 12VDC-120VAC Inverter, that is in excess of 40 amps of current draw from the 12VDC source, once you factor in the inverter efficiency. A typical car battery will net you about 40-50 Amp hours of capacity so in theory you are only going to run that stove for an hour on a fully charged car battery. Unfortunatly, a 40 amp draw is way in excess of the standard amp/hour rateing which is based on a draw over a 20 hour time period(2-2.5A) so you will lose a lot of energy to internal resistance of the battery(battery will generate heat). The high draw also shortens battery life. How you going to recharge the battery in an hour? There are some stoves out there that run on 12VDC motors and use a 120VAC power supply to feed this need when comm power is available. They are more easilly and more efficiently configured for 12VDC backup operation. If your power supply is in doubt, probably best to have a small genset on tap. This has the added benefit of giving you some light as well as some other creature comforts during a power failure(such as keeping the food cold).
   / any corn/biomass stove users #7
RonMar said:
... Typical pellet stove uses about 450 Watts under normal operation(700-900 watts during automatic startup). ...
I didn't realize they used that much power. That's over 1/2 HP under normal operation and a full 1HP at startup.
   / any corn/biomass stove users #8
I agree with Ron, the UPS would only last a few minutes and if you REALLY need heat during a power outage the only real way to operate a pellet stove ( or any stove that requires power) is to get a portable generator and run it off of that..
Like i said before. pellet stove are a great choice for some people and not so great for others... I would still think even if you had to buy your wood for a wood stove it would still have to be cheaper than buying pellets. i guess it would all depend on the burn times of the pellets and burn times of the wood, and the price of each...
   / any corn/biomass stove users #9
I bought mine this fall so still don't have a full years comparison. Kept the wood burner as a backup, but last month it saved $125 compared to last years bill at the ave. temp. within 2 degrees compared to my elec heating bill. Mine is an American Harvest by USSC and the only time I use pellets is to throw a handful in to start it. Then it's all corn. There are good and bad points to everything. Stove prices of the same brand and model vary quite a bit from dealer to dealer. A good site to look at is Iburncorn.com.
   / any corn/biomass stove users #10
I've run an older corn stove for the past few years, get my corn from a farmer so the cost is rather good. We would use about 4 ton up here for a season. I have burned wood for 30 years, and you can definitely get more heat faster with a wood fire. That said, as time sneaks up on us, the corn stove looks better all the time. It is much steadier and requires alot less tending.
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A54313)
2015 VOLVO VNL64T...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2020 Dodge Ram 5500 Auto Crane 6406H 6,440LB 3 Ton Mechanics Crane Truck (A52377)
2020 Dodge Ram...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
TEST YOUR BID BUTTON! (A54757)
TEST YOUR BID...
