HomesteadOC
I have a 77 Satoh Beaver S370D with a Category 0 3 point hitch and I have a bunch of IBC totes floating around different areas of the homestead in places that I dont really like them. If I had a set of pallet forms for the ol beaver then my life would be easier. My welder is a millermatic 110v mig so I cant really go too think with the steel (3/16?1/4 tops), and my welding experience isnt that extensive either, but I want a welding project and I need some way to move IBC totes. How much weight could my cat 0 hitch ideally be able to lift? I have a front loader for ballast and also was bucket forks, but Ive read that the 3 point can lift more than the loader and stay driveable. I have some totes filled totally with rain water, some partially filled, and some empty. Ive seen a lot of videos on youtube for inspiration, but I want something that is size matched to my lifting capabilities. Meaning not weigh down the 3 point with a set of forks and brackets that can lift 2 tons and my 3 point can only lift 1000lbs. Im not sure how much my hitch can lift, but Im hopefully assuming it can handle 1000lbs. A gallon on water weighs around 8.6lbs so that means I can lift 178 gallons of water and stay under 1000lbs, probably closer to 160-170gal including the cage, pallet, and tank.
