Antique pump repair
   / Antique pump repair #1
lhfarm
Veteran Member
Central Indiana
NH TC40DA
I have two pumps for our farm jeep (as picutured here Farm Jeep - Hydraulic Pumps) that I just picked up from a local hydraulic service company. They don't think they can repair them unless I have the worn shafts built up at a machine shop. A new pump would be cheaper according the tech. It was clear he had no interest in working on them.
I'm sure he is correct, but if I can get it repaired for the price of a new pump, I want to do that. I sent a note to Monarch Hydraulics the company that produced the pumps in the 40's and 50's. They wrote back that they don't have any parts or ability to service the old pumps.
My first goal is to try to locate a repair shop in central Indiana (I'm in Columbus) that might take on this project. Don't know if anyone might have knowledge of a good repair shop.
Plan B might be to see what I might be able to do. I've no experience with pumps. But I'm sure I could get it apart. Anyone with experience in rebuilding old pumps that might give me some pointers?
Thanks,
   / Antique pump repair #2
ihfarm, we need a picture of the guts of your pump in order to suggest solutions. If the shaft is removable from rotor, then replacement of shaft would be easy. If the shaft and rotor are inseparable, then building up the shaft via welding might be required. If the shaft isn't too badly grooved, then it could be turned (on a lathe) undersized and smaller ID bushings used in the pump. The technology to repair round shafts is well developed. Mechanics have been doing it for several hundred years.
-Karl
Thanks Karl. I'll take one apart this weekend and see what it looks like. I didn't want to give up and just buy new.
I sent a second note to Monarch and asked if they had any old technical drawings or specs, but they haven't responded.
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
(APPROX 12) 2" X 6" X 41" IRON TUBING (A51247)
(APPROX 12) 2" X...
2018 CATERPILLAR 318FL EXCAVATOR (A51246)
2018 CATERPILLAR...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
