Antifreeze solution Iseki with the Mitsi 3 cylinder engine
   / Antifreeze solution Iseki with the Mitsi 3 cylinder engine #1
Marcle
Herefordshire/Gloucestershire boarders UK
Iseki 2140
Checking out the users handbook, it doesn't say to use any particular type of antifreeze, what's other owners opinion on what to use please?
   / Antifreeze solution Iseki with the Mitsi 3 cylinder engine #2
I usually use a Prestone 50/50 pre-mix. I think it's good to something like -40 deg F. If you mix your own, I'd invest in some distilled water to mix with to keep the concentration of solids down in the system.
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2012 KENWORTH T400 TANDEM AXLE 24FT REEFER BOX (A51222)
2012 KENWORTH T400...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2 ROLLS OF CORNING OPTICAL CABLE (A50854)
2 ROLLS OF CORNING...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
