Antifreeze mixture warning
   / Antifreeze mixture warning #1
Ford850
Super Member
Ohio
Case DX55, Ford 850
I heard this on the local weather the other night, and was shocked I had never heard it before. They warned viewers to never use more than a 50/50 mix of antifreeze. I've seen this on the antifreeze jugs many times, but always figured a stronger solution was bad for seals or something. What I didn't know was as the concentration goes above 50% or 60% the freeze point also rises. A 60% concentrated mix will protect down to -60 degrees, but 100% antifreeze will protect only to -10 degrees.
   / Antifreeze mixture warning #2
The information I read gives the freezing point of 100% ethelene glycol as 8 degree's F above zero .
   / Antifreeze mixture warning #3
I knew it.
   / Antifreeze mixture warning #4
What many people also do not realize is what effect the water has . The water is what carries the heat or at least the majority of the heat both away from the engine ( summer months ) and to the heater , ( in the winter months ) .
See it every year , people over heated in rest areas or on the side of the road and they cannot figure out why since they they had straight anti freeze in the car .:rolleyes:
Fred H.
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2019 Allmand Night-Lite V-Series S/A 7kW Towable Light Tower (A52377)
2019 Allmand...
