Antifreeze/Coolant
   / Antifreeze/Coolant #1
jwillia2
guys, I have a family of JD's ranging from 6000 series to the good ol 55' series. My JD dealer insist on me using JD coolant... its 20 bucks a gallon!! is there any other subsitute i can use??? he says regular antifreeze has an additive for alum head motors that will damage the engine??? anyone else heard this?? any help would be grealy appreciated
thanks
justin
   / Antifreeze/Coolant #2
Go to the JD website and look at the on-line tractor manuals under the coolant section for the tractors you own. It seems each engine type has very slightly different requirements (anti-cavitation additives, anti-corrosion additives, etc.).
Look under the "coolant" section in the manuals and you will find the alternatives to JD COOL-GARD.
Shouldn't take more than 1-2 minutes per tractor to find the exact information you need.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2008 Ford F-250 XL (A50120)
2008 Ford F-250 XL...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
2017 Kubota U55-4 (A50120)
2017 Kubota U55-4...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
