ANTENNA
   / ANTENNA #1
fire526
Irons Michigan
LS XR4046HC
I just shredded the antenna on my XR4046hc, does anyone know where can get a replacement?
   / ANTENNA #2
Order a replacement from your dealer. I know of no aftermarket one that mounts the same.
I have to order one also. A low hanging pine tree branch snapped it in half. My temp fix was to slide some heat shrink on it and shrink it. My friends XR4140HC uses an all stainless antenna. Mine is flexible rubber coated wire. His shows the same part number as mine. Strange since they are different materials.
Antenna part no. 40249654, replacement screw part no. if needed is 40028703
   / ANTENNA #3
I have to order one also. A low hanging pine tree branch snapped it in half. My temp fix was to slide some heat shrink on it and shrink it. My friends XR4041HC uses an all stainless antenna. Mine is flexible rubber coated wire. His shows the same part number as mine. Strange since they are different materials.
SSB or VHF TV antenna? :giggle:
   / ANTENNA #4
Neither, Its for AM/FM radio in cab. I don't use my tractor enough to warrant installing a ham radio and antenna.:LOL:
   / ANTENNA #7
Of course!
I was being entirely facetious!
Thus the emoji.
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2000 OSHKOSH MILITARY M1070 TRUCK (A51243)
2000 OSHKOSH...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
2011 Mack CXU613 Truck (A52128)
2011 Mack CXU613...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
