another water well question?
   / another water well question? #1
BWS
seattle area
kubota l3830 hst/723 fel
we are in the process of getting a well drilled and will be doing the plumbing ourselves.what size is the ultimate holding tank[presurized]?? should we get one that can be barried??i see the amtrol tanks.the well x??models look to small i think anybody know what i should pay??thanks bws
   / another water well question? #2
I think mine is 80 gallon, family of 4. I've added 20 gallon after water softener, and I use an old tank for my yard and small orchard. You won't be unhappy with a bigger tank, especially if you have times of electric outage.
I would visit the water forum on Countrybynet. Several posts on wells and tanks.
   / another water well question? #3
</font><font color="blue" class="small">( You won't be unhappy with a bigger tank, especially if you have times of electric outage. )</font>
Well said... when our power goes out, we figure we have about 3 flushes before the pressure & volume peter out. Not bad if power is out for hour... but that every now & then when it's out for several hours, or worse winter... couple days... /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif
Well... let's just not go there
/forums/images/graemlins/blush.gif
   / another water well question? #4
When you're getting well quotes and trying to save a few bucks after the initial sticker shock, this is one place I wish I had spent an extra 2-300 bucks for a bigger tank. And it's easier on the pump too.
   / another water well question? #5
The size of tank is a function of a number of variables including well yield, water usage, and so on. The bigger the tank, the less often the pump has to cycle, and the less often the pump cycles the longer it lasts.
I was told repeatedly that I only needed a 40 gallon tank, so I put 2 side by side (total 80) and am satisifed with my decision. Maybe if I could have found larger ones I would have bought them, but I didn't.
One drawback to large tanks is that you rarely get a glass of ice cold well water, unless you fill your glass right when the pump kicks in.
probably saves electrical power since the water is warmer though.the tanks i,m looking at are amtrol and the smarttank by flexcon.just dont know much about tanks so i,m trying to get all the info i can.we are going to order a tank and hook it up to are old well then test the water with new tank[it will still fail the bacteria test due to ground water seapage]then we will have the new well drilled.we will check with the better buisness bureau to find out who's reputable.bws
   / another water well question? #7
The pressure tanks hold considerably less water then their physical size would indicate and are there simply to keep pressure on the water, without one, even a small one, the pump would turn on the instant you cracked open a faucet and turn off the instant you closed it. The membrane inside is mounted towards the bottom of the tank about 1/3 of the way up. It keeps the water and air from physically touching each other helping to maintain the amount of air in the tank. In the old days, there was no membrane and the tank needed a frequent recharge as the air joined with the water. Depending on your needs and budget, the more tank, the better. You can parallel many tanks or get one or more large ones. It's important to be sure the precharge pressure is maintained and should be checked once a year. It's easy to do and can help in the longevity of the tank. As mentioned, the less frequently the pump comes on, the likelyhood the pump will last longer not to mention the contacts that kick the pump in.
   / another water well question? #8
how do you check the precharge pressure of a tank??
if the old well didn't pass, a chemical injector to put clorox or some other "purifier" into the water will "ususally" solve that problem...
heehaw
   / another water well question? #9
Turn off the breaker for the pump.
Turn on a faucet and let the water pressure drain to zero.
With a tire pressure guage, check the tank pre-charge at the schrader valve (looks like a tire valve stem) which is usually on the top of the tank.
this old well is hand dug and by the sound of the ground and from what weve been told its a huge cavern.kinda scary.bleach or some additive might work.any other recs on tanks.will probably need to order tomorrow.bws
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
2025 International TMA Attenuator Truck (A52377)
2025 International...
2005 International 4300 Telsta Telescopic Bucket Truck (A52377)
2005 International...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
