ANOTHER tractor....
   / ANOTHER tractor.... #1
oz in SC
North Cackelacky...FINALLY.
None right now...
Found this one on Craigslist and emailed the seller,we might be able to work out a trade for some stuff I have for sale so that isn't the problem,distance is.
He is in Mississippi about 650 miles from here and 560 miles from our land in NC where we would want the tractor.
That is a LONG way to go to just look at something so I thought perhaps y'all might give an opinion on the tractor and attachments that go with it and any questions I need to ask.
Massey Ferguson 150 tractor, Perkins Diesel Engine, 5 foot john deere gyramower, 6 and half foot disk harrow. Will consider partial trades of motorcycle, four wheeler, or guns.
Massey Ferguson 150 Tractor
Additional info-has 'about' 3500 hours on it,power steering and from the pics looks nice enough.
Thanks for any and all advice.
   / ANOTHER tractor.... #2
Looks like she's leaking a little from the puddles in the pictures. She looks nice though! Good luck and keep us posted!
I noticed that too....have an email in asking about leaks and such.
Biggest issue would be the distance between us and getting it delivered or hauling it.
   / ANOTHER tractor.... #4
I'm a BIG fan of the Massey 150. I'll always believe it was/is the best all around utility tractor ever built.
But..... They're getting along in the years now. What was once the gold standard as far as fuel efficiency, the handiest tractor I've ever operated, and the best buy in it's size back in the day, may have a few issues.
If the oil stain on the ground is from the tractor, it's in a spot where the oil PROBABLY came from the weep holes under the bell housing. If it's engine oil, odds are it's the rear gaskets for the oil pan that is leaking. Rear main seals leaking is almost unheard of on that model Perkins. Pan gaskets leak quite frequently. AGCO/MF offers a replacement gasket set that, if installed correctly, ends that problem. If it's tranny oil, you may have a leaking input shaft seal, OR, if the tractor is equipped with MultiPower, there's several leak points. Probably 9 out of 10 Perkins 3-cylinders have a SLIGHT leak from the engine. So long as it's only a drop or 2 after a few hours of run time, no biggy. If you see significant oil leaking, it's time to drop the oil pan.
Looks like it has aftermarket rear rims (w/wide tires) It looks like a driving range or a batting cage in the background. Probably led a life as a "turf tractor".
I see the grill is missing, lights missing from fenders (both front and rear)
A nice 150 will sell for as much as $6500 here. Average price is around $5000. $4000 is either a bargain or a rough tractor here.
"Going rate" for hauling a tractor here is about $2 a loaded mile, so expect a price in excess of $1000 for delivery.
Myself? I'd look locally to avoid the haul bill.
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
