Another "too big?" thread
   / Another "too big?" thread #1
DH44
Bronze Member
North, Texas
Case DX45
I'm looking at upgrading my current tractor within the next several months. Currently I have a 2009 Case DX45 HST with cab,FEL. Like many folks, I have acquired implements matched to its size- a 6' disc harrow, box blade, bucket, landscape rake, etc. We have 130 acres and since we bought it I have been "domesticating" more and more of it. Right now I spend most of my tractor time shredding the areas I can get to, and the pasture I've been improving (about 50 acres total). The 45 has been ok, especially with the number of mesquite trees you have to maneuver around, but it's over 1400 hours now and the hydraulics are feeling "tired". We also have cattle, so during the winter I'm feeding large 6x5 rounds and the tractor is struggling with them. I also disc and plant about 20 acres of wheat every winter.
I've looked at JD 75,85 and 100 HP and Kubota 75 and 105 HP models. One of the most essential things for me is a good cab and AC. It gets HAH where we are, and the trees are frequently hiding wasp nests that don't like being disturbed. The Kubota only has AC vents coming out of the console, no overhead ones in the cab like the DX45 does. I have a friend that has a 100 HP JD and he says the AC is fine, but he doesn't use his near as much as I do mine.
There are also some good deals on the 105 Mahindras to be found, but I have no experience with them and don't know anyone that has one.
I think a 75 would probably do, but I'm retiring in 5-7 years and I hope this is the last tractor I buy. We could end up with more acreage, so I don't want to undersize, but I don't want to get something too big to maneuver, either. I'm usually of the "more than you need" mindset, but not sure about how big to go.
   / Another "too big?" thread #2
Got to admit - I had to look up HAH. Didn't think you meant Healthcare Assoc of Hawaii, either.
My Kubota M6040 is open station and 64 hp. However - in the fall I go to my nearest neighbor - 4.5 miles south and help him with the hay and wheat harvest. There I will get to drive large, cabbed air conditioned tractors. He has JD and Versatile in the 250-350 hp range. During fall harvest it can get to be HAH here, in our context. I'm amazed at the difference in the air conditioning between the JD and the Versatile. Quite honestly - I DO NOT like either. The cold air is blowing on me like an arctic blast out of PT Barrow and the sun comes in thru the massive glass windows - seems to get magnified and gets burning hot.
I've been in Houston once, in July. So I have a weeks experience with the heat AND humidity down there.
North Texas might be a bit less humid - Houston almost did me under. Having gone from Anchorage, AK where I lived. I was there for a week long meeting.
I am sure glad that, most of the time here, open station is very comfortable. We have our stinging bee types but not the ground dwelling type or the type that build nests in my pines. I can honestly say - I have never been bothered by any type of bee while operating my tractor on my 80 acres.
Because I have first hand experience with the two brands of tractor and their unique AC systems - recommend that you spend time, at the dealership, testing out the AC systems. This will be a MAJOR purchase, at least in my book, and I think you need time in each unit to experience "how it fits".
You know - I don't think we ever hear much from the fellow who says - Oh, H E L L yes, the tractor I just purchased is too big. Its usually the opposite.
Good luck in your search. I hope you find the perfect unit. I know for a fact - my M6040 is the last tractor I will own.
   / Another "too big?" thread #3
If you buy a new one over 74HP you are going to have to mess with DEF (diesel exhaust fluid) and that is a whole nother can of worms. Couple of vendors try to work around it using tons of EGR but that just dumps a lot more carbon into the engine and oil system. DEF is mostly good if you run the machine a lot (don't let it sit for a couple of weeks), but unless you run it hard and almost daily expect problems. We have 85 acres and I went with a Kioti RX7320 (about 40K with a loader) with the cab and powershuttle transmission. AC has overhead vents and works very well here in hot and humid central Texas, and the loader will lift almost 4K so hay will not be a problem. I am eventually going to get another bigger tractor for some future projects, but it will be a pre-emissions one like a Deere,
   / Another "too big?" thread #4
Since I'm spending your money, I would suggest the biggest and best. Go with a 100+ HP rig with at least a loader and cutter of your choice. And keep the Case too.
The reasons are multi fold:
- You may not get much in trade for the Case. Or at least what it could be worth to you.
- If you have some help, you could get the cutting done more than twice as fast.
- The 100 HP rigs will likely not be HST, and your current rig could be handy for delicate loader work like stalls and such.
- If you acquire more land, the larger tractor will help, but combined with the your current tractor you'll have more tools to chose from.
- You only need to upgrade implements that you need immediately for the larger machine such as the loader and cutter. The Case could handle the rest as needed.
I realize this is perfect world circumstances, and I'm the type of guys that thinks that if one tractor is good, ten is even better! But I think if you start looking at numbers, maybe it will come out as a wash.
   / Another "too big?" thread #5
As to slow hydraulics something is either wrong or more likely you have just gotten use to the tractor, my opinion. I had a 68 HP (m6800) kubota with open station. Farmed just short of 40 acres of corn or soybeans. I bought a JD 5525 with about 91 hp engine. You are talking about same percentage increase. I only planted row crop one or two years after getting the JD and did not get any larger implements but used those I did with the Kubota. Only exception was with the chisel plow was able to reinstall two shanks had to remove for the Kubota. What I found was I was riding heavier tractor (with cab and cold air) and air seat that was much smoother. The other thing was I picked up for such as disking or using field cultivator was my best guess at least two mph which percentage was is about 40 to 50% which is impressive. Running planters no improvement as planters were already being run at max speed.
I do think you will end up with bigger disk for a 6 foot is small for even 75 hp. At least here.
   / Another "too big?" thread #6
I just upgraded from a Workmaster 50 to a New Holland t4.75 so that I could get into a cab. I traded in a 2016 for a 1000 hour 2012. That model is New Holland's top seller. The comforts of a cab with the added longevity of a hydraulic shuttle and competitive pricing all add up to a good selling unit. I currently have 100 acres that the neighbor cuts hay off of about 70 but at his age that could be problematic in a year or two. Another farm of about 45 acres that requires bush hogging of about 15 acres or so. So far I am very pleased with my purchase. I would suggest what ever you get go with a hydraulic shuttle or power shift. Not aware that Mahindra has those options in that big of a tractor.
Thanks for all the good info. I had considered keeping the Case, but wasn’t thrilled about having to maintain two- and barn space would have to be expanded as well.
I have heard from a lot of guys that the air seat is worth every penny. A lot of my pasture is rough from grubbing years ago, but I’ve been gradually smoothing and dragging over the years. The Case will turn your kidneys to jelly after a long day bush-hogging.
Think I’ll check out a 75 Kubota and Case and Mahindra. My Case dealer now carrries Mahindra, too.
I wasn’t aware DEF was a problem if it sat. I am only at the ranch pretty much every weekend, so it would never sit more than a couple of weeks.
   / Another "too big?" thread #8
agreed on maintaining and space - more motors/tires means a lot of things - just traded personally because my dad is 80 and needed something to get in/out easier and not having the $$ to buy for himself, I made it happen and told mom - were doing this......he was so surprised and has a new spring in his step like a kid - get the air ride seat worth EVERY penny - drive and test for noise/AC - I help maintain over 400acres of CRP ground for others and we have 80acres of row crop. That cRP is tall/thick when mowing time comes around not to mention 2 yrs of growth - no 100hp tractor is going to handle that w/out slow mowing and watching temps - trust me I know. 15' batwings are what we run. Personally I went w/out an FWA - why, I never mow when wet, turns tighter, easier to see w/out tires blocking view of where im going, I don't feed cattle in the winter, I don't row crop very much just a little here/there and with that big of a tractor I have duals if needed I can slap on, it weighs plenty for what I have to do. I don't play in the mud, we rarely get enough snow to mess with and I have a skid steer for that. I do have a loader for it for dad as he likes to piddle around with that stuff and push trees/brush around fields. It our only tractor - what is it? Its a 5088 IH 135 to 140 PTO HP - I wanted to get a 7120/7220 but $$ and trading for a different sub compact kept me from that. Its very quiet, its very smooth with the air ride seat, the A/C in it is wonderful and is cold for sure!!! Never lack for power yet. yes its a 35 y/o tractor but whoa...............it even has a cup holder and I can listen to Bott Radio Network all day while mowing. I would look at the 5130/5140 Case IH, I would consider a MX110/120 - if you have a case ih dealer sitting there those are all great units and cold/quiet w/fwa if you want it - they are out there I have looked at a bunch of them - if you are wanting new...........so many options, no budget was mentioned do you have one? only units with over 75hp I believe are required to use DEF? I have heard Kubota are nice, will always stand behind the IH and Case IH stuff I have owned and ran. Not a clue regarding Mahindra. If size and weight are a concern, go with the FWA, u will want it from time to time pulling things and if you ever get in the mud. No perfect tractor, FWA and 2WD have their plus/shortcomings.
   / Another "too big?" thread #9
If you had good service with your Case and your dealer then look into the Case C models. It's the twin to the New Holland T4 series and I absolutely love the T4 series New Holland's which are just blue Case's and vise versa. They have one of the best cabs imo.
   / Another "too big?" thread #10
No personal experience, but a cab tractor is going to be my next big purchase after I finish paying off my wife's mini van.
Guy I bought hay from has three cabbed Deere's that are all M models and he swears that they are the best machines on the planet. He might be right, the M model is very impressive. No problems keeping cool while working all day long in the summer. He also just bought a brand new E model open cab that he doesn't care for. He calls it the Economy tractor that is used for loading bales at the house, but will never be used to do real work. I would be hesitant to buy a cabbed E model Deere if you are doing serious work.
My neighbor loves his Zetor. I always considered them to be kind of on the low end of things, but he has 240 acres and a 15 foot bush hog that he runs all day long during the summer and he loves it. I'll look at when I'm ready to buy, but I'm still hesitant.
Mahindra hundred HP tractors are made in Korea, and that means better quality then India in my opinion. I saw a used 105s for sale that was very tempting. If I had just a little more cash at the time, I might have gone into debt for it.
Kubota is king for a reason, but you pay for them being number one. I know they had some AC issues awhile ago, but that they where actually talking to owners and working on ways to improve their AC systems. Every time I decide to by something, from small tractor, to zero turn, to side by side, I always go to Kubota first, get a price, look at what they have, and then go to the other brands to compare. I've never bought Kubota, but it was always in my top three after looking at everyone.
Case kind of scares me. I have a 1988 Case bull dozer that they no long support. They just decide that it's not worth while to keep parts for it, so good luck finding them on your own. That mentality in a major company is disappointing. They sell their Farmall and other line of tractors, but they seem to be pushing Mahindra over their own brand. To me, this is just odd, and it makes me wonder whats wrong with their brand of tractor? Sadly for me, I just love that shade of red on the Case tractors. I don't want to make my decision on paint color, but I would be lying if it wasn't a strong pull for looking at Case when it's time to buy.
On the same note on paint color, LS is just the ugliest shade of blue that I've ever seen. The Zetor dealer also sells LS, so I might take a look, but I can't see having to look at one of them for the rest of my life.
I don't think that I would even look at any other brands.
2020 UNVERFERTH 332 LOT NUMBER 199 (A53084)
2020 UNVERFERTH...
Electric Mobility Scooter (A51694)
Electric Mobility...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
