Another tire issue (flat)
   / Another tire issue (flat) #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Bought tractor at auction.
Using to cut fields & had a flat in front tire. Put NEW tire on and carried on.
Saturday, had a flat (new tire :mad: ) No biggie... I can put a plug in it...
Only to find out the co-op put a TUBE in , with the new tire :mad: :mad: :mad: :mad: Now I've got to deal with the tube...no wait...I'll just remove it and then plug the hole...oh , wait...I CAN'T, because the valve stem is connected to the inner tube :mad: :mad: :mad: :mad: :mad:
Ok, so a quick trip to Walmart, found a stem that would work, got some tire slime and plugged the hole...tire is fine.
Go out today to cut the fields and the freaking OTHER front tire is now flat :mad: .
This is an old, weathered looking tire... it has a tube in it.
I get to thinking... maybe I can go BACK to walmart, get another valve stem, yank the tube out and fill it with slime....
Go to store, got valve & slime. Went home and removed tube.
I am now, unable to get the tire to seat properly. It will NOT go on. I've got dish soap around bead to help it slide on and all its doing is blowing bubbles at me :rolleyes:
I've decided I'm going to just schlep the tire to the co-op tomorrow and have them put a new tire on WITHOUT a tube in it.
During this process, I got to wondering about the tire slime....
Is it better to put into a tire WITH a tube or WITHOUT a tube or does it really matter?
I got to thinking about the poor guys at the tire shops and the possible surproise they might have when goo drips all over their machine. :eek:
   / Another tire issue (flat) #2
Actually there are different versions of Slime for tube and tubeless tires...
   / Another tire issue (flat) #3
Actually, its better to plug a hole if you know where it is, rather than sliming the tire, if you have the time. Reason is is that once you slime a tire, the slime interferes with any future plugging you may try to do. It dirties up the plug, and it doesn't seal properly. I take a little soapwater in a spray bottle, and spray the tire till I find the leak, then plug it. Whenever I have used slime, I have found that it merely slows the leak, never quite stops it like a plug!:cool:
I'm with you here however, I'm sick & tired of some of these flats. This spring, bought brand new tire (for different tractor)...out cutting some of the fields that havn'et been cut in several years.
Came home with flat front tire... put a plug in... a second plug...a third plug :rolleyes: a FOURTH plug :mad: and finally a FIFTH plug :eek: . I guess I ran over some locust or something...:(
This cutting season, I've been running two different tractors (trying to decide which to keep/sell) and I've had two rear flats and four front flats with some of the flats having multiple issues.
It's been so bad, my father in law said just yesterday "Well... maybe if we keep getting all these flats, we just need to stop cutting the farm altogether"
:confused: :confused: :confused: :confused:
He seems to lose sight of (my opinion) that if we (he) had kept the stinking farm cut for the last 5 years, most of this growth wouldn't have developed little woody stems to create all these little tire daggers!
IMHO, the logical answer to all these flats isn't to abandon maintaining the farm, it's to better bulletproof our tires!
   / Another tire issue (flat) #5
Filling tires with foam is probably pretty rarely done because it's so expensive, but you just might be having enough flats to make it worth the cost.
   / Another tire issue (flat) #6
Are you over sharpening your bush hog blades? dull blades wont leave near as many tire eating spikes. How wide is the bush hog compared to the tire width? Do you constantly have to put the tires in freshly cut stems? Would a wider mow path keep your tires out of harms way? How tall are you leaving the stems? maybe cut them shorter with softer tires that would deflect and not puncture, or cut them longer stiffen the tires and have them push stalks down instead of puncturing? Of course this may be overthinking the problem, foam the tires and dont ever worry again.
   / Another tire issue (flat) #7
I've found that I don't have near as many flats when I went to tubed tires and Berrymans tire sealer. If the tire won't seat on the rim, just put a tube in it.
   / Another tire issue (flat) #8
Another approach would be to tube the tire, and install a tube liner, which acts like a shield to keep thorns away from the tube. Gemplers sells the liners and tubes if you need them:D
   / Another tire issue (flat) #9
Had you ever thought about patching the tube?
   / Another tire issue (flat) #10
I am not sure if "Slime" is a brand of no leak or a generic name. I have used Gempler's product (can't recall the name; something like "Bulletproof") in front tires for many years and it has not failed to stop a leak yet, including large ones caused by spiked stumps.
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
