Another pt wouldn't start
   / Another pt wouldn't start #1
ClintBlake
Bronze Member
Mechanicsville, VA, USA
Power-Trac PT-422
Another pt wouldn\'t start
Just before BobRip and I made our trip to Power-trac Mecca (other wise known as Tazewell), my 5 year old pt-422 wouldn't start. This left me with a delima - brand new grapple bucket and mini-hoe, but no tractor.
When I turned the key to run, I could hear the fuel solenoid click, but no head lights and it wouldn't even try to turn over. The battery was fully charged so I checked the fuse down by the starter solenoid, checked the ignition switch, and found out that I had 12v at the switches battery terminal with the switch off. If I turned the switch to run, the voltage dropped to about 7v and if I turned the light switch on it went to essentially zero. Based on this information and the "high quality" of the fuse holders that power-trac uses, I replaced the fuse holder.
Same results as before so I pulled the battery terminals and cleaned them just to sure. Same results so I measured the voltage at the starter solenoid. Key off - 12v, key on - 7v. Pulled the battery cables, cleaned everything, measured the cables resistance (essentially the same resistance as my meter leads) and put everything back together.
Guess what - Same Results. Gave up, drove to the auto parts store and bought a new positive cable. Put the new cable on and the tractor started right up. The old cable doesn't show signs of corrosion or any damage, and it measured very low resistance. Even when I wiggled it the resistance looked good.
   / Another pt wouldn't start #2
Re: Another pt wouldn\'t start
I have never seen that before. Bring in the cable on Monday and we can check it with the 4 wire Ohm Meter. If you had checked the voltage drop across the cable with and without a load, you could have isolated the problem completely before buying the cable. Looks like you found the problem. I have to see that cable.
MilliOhms Strike Again!!! /forums/images/graemlins/crazy.gif
Bob Rip
   / Another pt wouldn't start #3
We checked out the cable with the 4 wire Ohmmeter at work. It will measure down to microhms. We could see a shift in the resistance when we wiggled the battery clamp end. There was no appearance of any damage to it. I had never seen a failure like that before, but the old guy in the shop said he had seen this happen before.
Bob Rip
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2015 Ford F-450 Service Truck, VIN # 1FDUF4GT7FEC15731 (A51572)
2015 Ford F-450...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2017 Chevrolet Silverado 1500 (A52377)
2017 Chevrolet...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
