Posthole Digger ANOTHER POST HOLE DIGGER QUESTION
   / ANOTHER POST HOLE DIGGER QUESTION #1
Anonymous Poster
Epic Contributor
Hello, I purchased a used PHD with no Operators manual. My question here is regarding lubrication in the gearbox housing of the PHD. There is a "screw in plug" on the top and a "screw in plug" on the upper side of the housing. I am assuming that the top plug is for filling and the side plug is used to determine fill level and to drain if needed. My
question is what is the correct lubrication for a PHD housing? It smells like HD gear oil. I DO NOT know the make but am assuming that all PHD housings might take the same lubrication. Am I correct about the side plug being for fill level? I would greatly appreciate any advise. I wrote earlier about the stuck PTO shaft and those that answered were so helpfull. Thank you.
   / ANOTHER POST HOLE DIGGER QUESTION #2
In the worksaver line of phd the answer is yes the side plug is for fill level, and the lubricant is 80/90 weight gear oil, buying it used a flush and fill might be in order than you know for sure what its running with, good luck. Tim
   / ANOTHER POST HOLE DIGGER QUESTION #3
I agree with BuningTreeFarm, 80/90 weight gear oil is what I put in mine. The side hole is the fill level. Don't overfill it or you'll blow a seal....
Henry
THANKS GUYS. I THOUGHT THAT I MIGHT BE RIGHT ABOUT THE LUBE BUT IT IS MUCH BETTER TO ASK THAN PAY FOR NOT ASKING LATER. THANKS AGAIN
   / ANOTHER POST HOLE DIGGER QUESTION #5
80-90 weight oil in the gear box for mine. Take both plugs out. Fill from the top one. When oil runs out the lower plug your full. Thats the way mine is. 2/3rd's full is what it recomends
Larry
TRAILER AXLE (A51244)
2020 KUBOTA RTV...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
John Deere 693 Corn Head (A50514)
John Deere 693...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
