Another Ouch
   / Another Ouch #1
Jag
Central Arkansas
Kubota /L2650/ LA450/B4690 -- John Deere 450 Dozer
We did another one... Removing some old stumps that where left from last year, I was looking back to watch the chain, and the front bucket was just the right height to roll a smaller root ball up under the front end. It broke the hydralic line fitting for the steering cylinder... This is about the third time I have tagged the line, but the first time I tore it. I really, REALLY dislike the hydro lines being in front of the axle along with the steering rod. I can never keep the dust fittings on the knuckles... All of it should be behind the axle.... As anyone else done this working in the brush...
   / Another Ouch #2
Could you rig up some sort of shield to keep this from happening. Maybe if you took a pic of it, someone here could give an idea or two and what you might be able to do....
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2023 Vivid EV Electric Cart (A51694)
2023 Vivid EV...
42013 (A51691)
42013 (A51691)
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
