another noob (from the south) question...
   / another noob (from the south) question... #1
/pine
Super Star Member
We are expecting up to 12" of snow...
I have a 4x4 tractor w/loader (17hp) with a very heavy rear blade mechanical angle/hydraulic pitch (reversible) total weight maybe 2500#
I also have a ride on 4x4 Ditch Witch (45 hp) with a front 6-way blade (fully hydraulic) weighs probably 5000#
This machine has wide tires and a very low center of gravity...
Which would work best on a hilly/curvy mountain gravel road ?
   / another noob (from the south) question... #2
The tractor for sure,use the loader to push and rear blade.
   / another noob (from the south) question... #3
For a curvy hilly road, I would think the heavier and low COG machine would fair a little better getting around.
I think the tractor with combination of FEL and rear blade would be better, but its light and if conditions dont let it get around well, try the ditch witch
Thanks..
Either way it is going to be a learning experience...I do have some sections of the road I can "practice" on...
I wish I would have taken the back hoe off the ditch witch before the weather moved in...
   / another noob (from the south) question... #5
Leave the back hoe on the D-W. It will be extra weight for traction.
   / another noob (from the south) question... #6
2500 pounds seems to be pushing the 17 hp tractors workable limit!
That's the weight of the tractor with the blade...I can load the bucket with gravel to add another 400#'s or so...The rear blade probably weighs about 450#'s...
   / another noob (from the south) question... #8
The rear blade is way too heavy. You'll end up digging up your driveway with it. I've a very light weight (easily moved by hand off the tractor) back blade. It bites into the snow because of its curvature and the pitch angle of the blade. Don't need blade weight to cause it to bite unless you're trying to clear sleet. For sleet, the weight helps. One year here, I couldn't touch the 7" of sleet that we got but happened to have an old (very heavy) Gravely square chute snow blower. It hunkered down and bit to the bottom of the sleet and slung it about 50 ft or so away.
Ralph
   / another noob (from the south) question... #9
Oh that sounds better :drink: Get much snow where your at? I was just reading a thread on a fella that was worried about 2 to 3 inches and what his options were to remove it.... I think he was either from north or south Carolina , Heck if it ws me I'd leave it it will melt i no time! good luck
Ralph
The blade is reversible and besides the hydraulic top link I also have an additional pitch cylinder on the blade itself...I can feather it (backwards or forwards) to nearly parallel with the ground...3PH has position control...
EZ-GO Electric Golf Cart (A50324)
EZ-GO Electric...
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
