Another newbie question.
   / Another newbie question. #1
gitrdone
Calaveras Co, CA
Hello everybody. I am shopping for a tractor for our business and am totally new to the world of tractors. We need a tractor to knock down brush, build small roads/trails, grade our existing roads, and dig trenches for water and electrical lines. Can anyone recommend what the minimum amount of horsepower I should be looking at to do a fair amount of trenching in soil that can be hard in places? A Mahindra dealer I've spoken to has suggested the 3215. A magazine article I read said that you should not consider a backhoe attachment on anything less than 50 hp, so I'm wondering if the 3215 is going to be powerful enough?
Oh, and we're on a budget. :)
Thanks!
   / Another newbie question. #2
Thanks!
For some applications you need the weight and digging depth-strength of a 50HP, or maybe even a 75HP tractor. Yet a lot of guys accomplish a huge amount of work with backhoe tractors around 20HP that may only weigh 3000 lbs total. So it all depends on the task, the speed at which you want to accomplish same, and any physical limitations, like needing to lift high enough to load a real dump truck, dig deep enough to put in a septic tank, lift objects that weigh a bunch, etc. If your tasks can be broken down into small bites, even a real small tractor will do. That being said, the 3215 Mahindra is a real nice medium size compact, built in Japan by Mitsubishi. The loader and backhoe are USA built. Great quality rigs. Mahindra makes backhoe tractors from 18-75 HP, so you can have a lot of options in that brand.
   / Another newbie question. #3
Thanks!
Welcome to TBN...Not sure about the 50 hp backhoe attachment thing but it's all relative to what your applications are...You'll probably hear that bigger is better...Good luck with your pick.
Don
   / Another newbie question. #4
for not much more than that 3215 (or 3316, if they're out of the older model) you could get a 4110 (also last year of production) which is a frame size bigger and therefore heavier, which translates into better traction for ground engagement and BH work.
OTOH, I completely understand budget restrictions.
you might also check around for a used machine in your price range. I had a demo model Branson 4720 with loader quoted to me at $16,100 this week. BH would add $7k to that, installed.
   / Another newbie question. #5
Thanks!
Did you know that ya can't beleive every magazine article u read?
   / Another newbie question. #8
Depending on the amount of trenching and all the specs with it, you might find a trencher to be better option for that than backhoe. Depending on your needs there you might be better off renting a large trencher. At same time depending on all specs you might find you are better off hiring such done or renting a machine just for the digging. If you will be doing trenching often then your probably will be better off buying. Still think you will find trencher is faster than digging is. Of course the backhoe has advantages.
   / Another newbie question. #9
I hate to say it.. but this almost sounds like skid-steer teritory.
in any case.. a backhoe on a cut, if it has a subframe, is ok.
soundguy
   / Another newbie question. #10
The trencher suggestions are good ones, if you know you only have a few, or that they will always be narrow. The backhoe lets you dig BIG holes and big trenches too.
If you get a QA bucket and front remotes, you can buy or rent a trencher attachment for the front of your tractor, assuming you get a tractor with enough HP to drive it. This is where the skidsteers excel.
For narrow, shallow trenches, say for a water line, a cheap middle buster can be used on a tractor. Very fast. And there are some other inexpensive implements specially designed just for this purpose too.
If you go with backhoe, here are few things to consider:
Weight of tractor is king - will help you get the most power out of your backhoe
Reach is a consideration, limited by tractor size: 20 hp = ~6.5', 25-35 hp = ~7.5', 35 - 45 hp = ~9', etc. Don't under estimate it.
Get subframe mount only, NO 3PH backhoes.
Good dirt and/or pavement pads are a must.
Good large (1/2" hoses) to rear remotes are better (faster). Rear remotes make backhoe on/off a little easier than long plumbing. Then rear remotes can be used for other purposes too.
Pay attention to hydraulic pump capacity of tractor. More = faster working.
Get a proven backhoe from a reliable manufacturer.
Consider a true TLB (like a Kubota B21 or B39), flip over seat, closer hoe to tractor. Heavier duty.
For CUTs, I think Branson is the heaviest, followed by Kioti and Mahindra. Kioti's have excellent pump capacity. The Kioti CK20 is good for it's size, if you don't need the reach or more hp power for other things. But, I'd opt for the bigger CK27 (or CK25). Or, if you think you need the PTO HP, the CK30 or CK35. I also like the TYM T273 or the new T353.
I'd definite check them all out, and look used first.
2013 PETERBILT 388 VACUUM BOBTAIL (A53843)
2013 PETERBILT 388...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2004 Kubota L4630 (A50123)
2004 Kubota L4630...
