Another leak
   / Another leak #1
countrybumpkin
Elite Member
Kioti, kubota
Well I was cleaning the NX5510 and noticed another hydraulic leak, this one is between the left axle housing and brake case. Appears they use sealer instead of gaskets on these so I'm guessing they missed a spot or had it to thin in a spot.
   / Another leak #2
Is it an easy DIY to fix or do you have to get the dealer involved.
   / Another leak
It would be a easy fix, but it's under warranty along with the 3 pt lift cylinder. Thats only reason, minor issues really but still a bit frustrating.
   / Another leak #4
Never do yourself if under warranty
Sounds like some disassembly required to fix properly
Good luck
Joel
Interesting I've been having many issues with seals in my backhoe control valve. My 30 year old Kubota had no such issues
My 12 year old Kioti is another story. With that said the problem is the backhoe valve body in my case and limited to a particular seal used on the spools
I'm sure dealer will sort you out
Joel
2019 John Deere 3025E (A50120)
2019 John Deere...
2020 Kia Sportage LX SUV (A50324)
2020 Kia Sportage...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
1999 Chevrolet 1500 (A50121)
1999 Chevrolet...
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
2007 JLG SkyTrak 10042 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
