Another Leak Down question
   / Another Leak Down question #1
granite
I have a BX23 with about 300 hours. While operating the tractor - loader work - the BH's main boom leaks down about 1/2" per hour. Last night I tested the leakdown rate while stored and the drop was insignificant overnight. I don't have a problem with leaving the pin in the BH and I always lower the BH and loader when not in use. I've searched/read posts about normal leak down and how it can be expected with compact tractors. The 2-year portion of the warranty is just about up and I have never had the need to bring the machine back to the dealer as I do all the routine maintenance myself. Aside from the self inflicted broken hose etc, the only other problem with the tractor is the sticking lever/pin when removing the BH. None of these problems seem significant enough to have the dealer come for it and I would prefer not to loose any seat.
Would you have the dealer come and take a look or would you just accept these things as minor annoyances.
   / Another Leak Down question #2
A 1/2" per hour for boom droop is normal to good. You should always pin or chain the boom when not digging. It's a good habit to form.
While forming the habit, don't forget to un-pin or un-chain!
jb
   / Another Leak Down question #3
That is well with in acceptable level. Your ½” per hour is very low compared to many. JD is the only one that has the levels listed on the net as far as I know. Their acceptable levels are really out there.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
JOHN DEERE 700M LOT NUMBER 35 (A53084)
JOHN DEERE 700M...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
