Another L3800 Question?
   / Another L3800 Question? #1
bookemdano
Bronze Member
Tennessee
Kubota L3800 & BX2680
While lubing the HST zerks which seems to have cured my starting problem though only time
will tell, I came across this:
I've been under there dozens of times, but I don't remember this. Reason I'm asking, I had
it serviced last fall to include topping of the Tranny lube. Doing maintenance on it today,
it took nearly 3 gallon of UDT-2 to top it off. I was back under it looking for a leak and disn't
find one anywhere. This looks like some kind of pop off pressure relief valve on the tranny.
Is it supposed to be exposed like this? And could this be the reason I lost 3 gal of UDT-2?
I'd appreciate it if someone with a L3800 would check theirs and see if it's open and exposed
like this or if I'm missing something?
Dano
   / Another L3800 Question? #2
Dano
That is a drain for the clutch bell housing. It is there to allow condensation and oil to drain out. It should normally be dry but if you have an oil leak from either the transmission or the engine seals it will help keep oil from building up and contacting the dry clutch.
3 gallons of fluid is a lot to lose. Is that area wet with fluid?
   / Another L3800 Question? #3
Is that the drain for the bell housing? Loose pin in fitting to keep the drain open. Engine oil from rear seal or transmission front seal. Or any water intrusion. Keeps the clutch dry.
Time for owners and shop manuals.
That's just it, the ground where I park it is dry and so is the bottom of the
tractor. I'm beginning to think they didn't top it off last fall and I just thought
I checked this spring. We have had a wet spring and summer and we came
down with covid (and no, we are not jabbed and won't be either) and I didn't
do near the work I would normally have done. Last winter I used my BX2680 FEL
for what little snow I needed to remove. I'm beginning to think I was
charged for 7.5 gal of Super UDT2 and didn't get it. I hate to think that and I know
accidents happen but still?
Dano
   / Another L3800 Question? #5
Ought to check fluids more often especially after service. Helps keep everyone honest and best health of YOUR tractor. 3 gallons is a significant loss over how many hours?
My L3800 only has 211.3 hours in it. Had it serviced at 175. So it's only had 36.3 hours
put on it since that.
Ordered a bottle of John Deere dye for hydraulic oil and I'll drain it then when I can see it in the
sight glass.
Dano
So I have to ask, did you fill the hydraulic tank up until it filled up to where you add the fuild?
And poured out. Never saw the first indication of fluid in the sight window. When the dye
gets here, I'll drain a qt and then add the dye. Run it very gently down the drive and
back to mix the dye then drain it a qt at a time until it's registering correctly.
Dano
   / Another L3800 Question? #9
The sight glass is a good idea but the reality is can be difficult to see even when at proper level.
Might have to order a bottle of dye.
Post if adding dye is worth it...
I will.
Dano
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
Tiger Saber Flail (A50860)
Tiger Saber Flail...
Fuel Tank (A50860)
Fuel Tank (A50860)
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
Falcon Power 4-Gallon Air Compressor (A50860)
Falcon Power...
