Another JD 4X10 question.. LoadMatch...
   / Another JD 4X10 question.. LoadMatch... #1
del
too many
This 4210 as a button called "LoadMatch"
The manual is extremely vague on this. It is designed to
help keep the tractor from stalling during loader use. What
does it actually do, and why wouldn't you want it "on" all
of the time?
Nitrous boost, turbo kicking in, extra cylinders now getting
fuel? Super granny low range activated so it won't stall but
will move at .0000001 mph?
I have this thought that if I pry up all these buttons there
will be no wiring behind them, that they are all placebos!
Have some of you played with this much?
thanks
del
   / Another JD 4X10 question.. LoadMatch... #2
Loadmatch watches for the engine to start lugging, and makes split second adjustments to the tranny.
Put your machine in "C" range get going pretty fast at about half throttle and point up a grade. Do that with and without LoadMatch and you'll see it working.
Now - If you ever use that shiny new bucket....
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
Mini Excavator Attachment Set (A50121)
Mini Excavator...
