Another Injector Pump Broken Gear
   / Another Injector Pump Broken Gear #1
Kioti Paul
Weatherford, Tx
Kioti DK45SC
I just completed replacing the 'pinion gears' (control sleeves) in the injector pump of my DK45S, & I would like to chip in my 2c worth on the subject. 1st, I would like to say what a fantastic resource these forums are! I really appreciate the "2881neches" tutorials on the removal & repair of his IP, OH MAN, I wish he had written our service manuals, life would be a lot easier. Also, I really appreciate "ritcheyvs" for all his work in compiling all the reports of the failures & solutions to the IP problems. Finally, all the people who have posted suggestions, solutions, & recommendations on shops to get service & parts are all greatly appreciated by me & I am sure by A LOT of others. I followed the suggestion from "brotsten", & called H&H Diesel Repair in Fife, Wa to get the parts. I can highly recommend them, they were very professional, & friendly. They had 3 of the sleeves in stock, got the 4th one the next day, & mailed them that same day. Less than a week after ordering them, they arrived at my front door in Texas! That's not bad, for ground shipping. Also, they charged $9.32 (each) for the sleeves ($63.32 total for 4 sleeves + shipping). These are the exact same Zexel gears the other shops sell for $25. Either price is still a huge bargain compared to the $1500 Kioti wants! My tractor is back to running as strong as ever, & for less than $100.. Thanks, Guys!!!
The main reason for I am writing is concerning 'timing' the new gears to the rack. As I read all the posts, I noticed a couple of posts asking about how to 're-time' the gears (I also had been wondering about it), & it seems to me that no one really addressed it. I think maybe no one has addressed it, because after you pull the springs & plungers out, it is pretty evident how they are timed, but still it's nice to know before you start. The rack has a thin radial groove that (when the rack is centered) lines up with the center line of each gear (control sleeve). Gears that have teeth all the way around them have a tiny 'timing' mark on one tooth that lines up with the radial groove on the rack. The gears that have a blank spot on them do not have the timing mark. There are 29 teeth around that gear. Use a 'sharpie' with contrasting color (silver, copper, etc) and mark the 15th tooth as counted from the 'blank' spot. Make sure that is the "1/2 way" tooth (exactly opposite the blank spot). When you have removed the spring, the plunger, & the spring seat, you can look through the bore, & clearly see the groove around the rack, & it is simple to line up the marks on the rack & the (control sleeve) gear.
When my pump failed, it stuck at about 3/4 throttle. That is a real eye opener!! My tractor has the manual shift transmission, so I was able to shift into high gear, pop the clutch, jam on the brakes, & stall out the engine. I thought right then that I was very lucky I didn't have the hydrostatic trans!! I then read a post where this same thing happened to a man that did have a hydrostatic transmission. I REALLY feel for that fella! What a helpless feeling that would have to be! Then I got to thinking about my lawn mower with a Kubota engine & hydrostatic trans. It turns out that it has an electric fuel pump, & after a little experimenting I found that when the pump is shut down (unplugged), the engine dies within a few seconds; so I guess I'm OK.
With a little searching, I found electrically operated, diesel fuel shutoff valves designed to shutoff unmanned, stationary engines in case of overheating, (or low oil pressure). They are a little pricey ($100 +/-), & I feel in my situation at least for now, I would be able to handle another 'runaway', even if full throttle. But if I ever get a tractor (any brand) with a hydrostatic trans, one of the first things I will do will be to devise a way to positively shut off the fuel (from the seat)!
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2019 JLG 2632ES 26ft Electric Scissor Lift (A50322)
2019 JLG 2632ES...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2002 TCTC 6'x12' Trailer (A50121)
2002 TCTC 6'x12'...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
