Another I Match question
   / Another I Match question #1
unreconstructed
Platinum Member
West Texas
JD 5325 JD 5203 JD 2320 LT 133
I live in cotton country in West Texas, so the JD folks have nearly no knowledge about Cat 1 and Cat 2 equipment.
I have a 5203 and 2320. Am considering going I Match on the 2320 and have noticed that the Cat 1 I Match is on the 5203 "build your own". Just wondered if the Cat 1 I Match is stout enough for an MX 6 which I have on the 5203. Also, JD list a Cat 2 "Economy Quick Hitch" which looks similar to the I Match--at least in the photograph.
Would appreciate any thoughts anyone has about the quick hitch options for the 5103 series.
Also, a great thread about the pins for the I Match.
Thanks for your help as always.
   / Another I Match question #2
The Cat I I-match on the MX 6 mower is plenty strong enough. Unless you are only going to use the i match on JD i match capatible equipment, I would go with SpeeCo or another brand. I match only seems to fit well on JD/Frontier equipment. Speeco/HF has an adjustable top hook (JD is a fixed hook) and has an adapter to replace the hook if needed and will therefore work on most 3pt equipment, if the implement pin spacing/width is right.
I have both Speeco and Harbor freight and would recommend the Speeco. The spacing/width is better on the speeco and the Speeco will accept the recommended Cat I bushings. HF has smaller lift hooks and can't use the bushings. (I didn't know this until I bought the HF, widened the spacing of the lower hooks). All of my attachments already have the bushing on them and the HF won't work until I torch the hooks larger. (Another project). Speeco will come with the adapter and one set of bushings. Speeco however costs about 2-2.5X more. I match costs more than the SpeeCo and IMHO less adjustable.
Remember, you can't use Cat I hitch on one tractor and Cat II on the other tractor and expect them to work on the same implements.
I appreciate much your input.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2021 Kubota KX057-5 Midi Excavator (RIDE AND DRIVE) (A50775)
2021 Kubota...
2014 Chevrolet Cruze Sedan (A55758)
2014 Chevrolet...
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
