Another Etiquette Question. Please Help!!!
   / Another Etiquette Question. Please Help!!! #1
CenturyGreg
Western Pennsylvania
Century 2028 C-50HL FEL
I bought a brand new tractor on Saturday with less than 1hr. on the tach. After getting it home, it immediatly developed a transmission problem (1.2hrs. on tach) that appears to require the tractor to be torn apart and the transmission be opened to find the problem. I hate the thought of buying a brand new tractor and having it split in half already to be repaired. The tractor is the last of the 2004 models and the tractors changed for 2005 or I would probably ask them for a new tractor. The dealer does have a 2004 model that is a larger horsepower than my tractor. My question is, do I have a leg to stand on to ask for a new 2005 model or the larger 2004 model, or do I simply have to let them repair my tractor and pretend I like it? /forums/images/graemlins/confused.gif
   / Another Etiquette Question. Please Help!!! #2
Greg,
I think that you are letting this get out of hand. It is easy to imagine something really bad, if you let yourself. You have yet to find out what is wrong with your tractor. Let the dealer look it over, before you expect the worst.
BTW, welcome to TBN.
   / Another Etiquette Question. Please Help!!! #3
Good Morning
I agree with Greg. Sometimes these things seem worse that they really are.
I can only speak for myself, but it would not bother me in the least to have major surgery done to a tractor at 1.2 hrs. That's why I have a warranty. They way I look at it, I am just saving someone else from going through that. My JD4310 had numerous things handled under warranty, the dealer always picked up and delivered for free and the bill always was zero.
Good luck
Richard
   / Another Etiquette Question. Please Help!!! #4
I wouldn't like it, but a warranty starts as soon as you own the tractor, probably better to have the problem happen right away than 200 hours down the road.
I would certainly expect a similar model loaner and know I wouldn't have a problem getting one from my dealer.
   / Another Etiquette Question. Please Help!!! #5
I think I would be more concerned with transportation charges. We had a hydraulic leak from day one and when they finally came to get the tractor they charged us transportation charges both ways on a problem that existed on a tractor even before we got it. I hope your dealer will elect to eat those charges.
   / Another Etiquette Question. Please Help!!! #6
First off, this is a business question, not etiquette.
I would do as the others mentioned, not worry and let them check it out.
But, I would also let them know that it was up to THEM to have checked the tractor over before delivery. 1 hour on the meter isn't enough in my book. My dealer would have just gotten it warm on the Dyno by then...
I would also be documenting things, and checking on their reputation carefully. You might not have anything to worry about, but you may be just at the tip of lotsa problems, and the sooner you act the better.
1 hour on the meter at delivery doesn't sound like it was checked too well....
   / Another Etiquette Question. Please Help!!! #7
I would not get to worried about it either. I had a problem with mine right away where I could not shift from forward to reverse. At first they thought they were going to have to split the tractor in half but it ended up just being a snap ring that broke and the piece was lodge where the linkage would not move sometimes. While the tractor was there the mechanic who was a machinist did a lot of beefing up of the linkage and braces on several areas of the tractor. So everything ended up better than okay.
   / Another Etiquette Question. Please Help!!! #8
I tend to agree with the others. These tractors are far less complex than a truck. My new 2004 Ford F250 CC power stroke with the 5 speed auto had the tranny rebuilt (actually the reverse planatary replaced) at 47 miles. The 2005 trannies are loosing a snap ring and blowing a hole in the tranny. The point is if it is fixed it is fixed.
   / Another Etiquette Question. Please Help!!! #9
Yes, I think you have a leg to stand on. If you will not be comfortable with the tractor after this, why not talk it out with the dealer. Maybe this is just the push you need to jump into the 2005 model. I hope the dealer will work with you and do what it takes to make you happy.
Moon of Ohio
I realize that the problem could be anything, I'm just trying to figure out what to do if it does turn out to be the worst. I plan to let the dealer figure out what the problem is before I plan to do anything rash, but if they call & say they have my tractor split in two I want to have a game plan. I also realize that the dealer does not build the tractor, I'm sure they are about as upset as me. I simply would rather not have a brand new tractor that has had the tranny tampered with already. Thanks.
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
2015 Freightliner M2 106 Ambulance (A50323)
2015 Freightliner...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
