lhfarm
Veteran Member
I've read most of the threads here. My barn is ~430 feet from my garage/workshop service entry/panel. The garage has 200 amp service and that is where I have my welder, compressor and work tools. The barn needs lights, power to run my block heater and the occasional power tool. I did think I should plan for taking my stick ac/dc welder (on a 50 amp circuit in the garage) there for the occasional repair.
I called a local elecrical contractor and he just gave me a bid for wire, 100 amp panel in barn and installation of breaker in garage box.
- for #2 $1400
- for 2/0 $1900
To put the wire in the ground is an additional $500. I told him I had a BH, but I think he wants to send some work to his digger.
I'll add that neither the garage or barn are finished, so working on the panels isn't hard. We don't need an inspection. Some questions:
1. Do his numbers seem really high?
2. Would 2-2-2-4 AL dropped to 75 amp work (I used the voltage drop calculator and I think it would work to run my welder)?
3. If I follow this plan http://www.tractorbynet.com/forums/...1d1180903741-electric-service-barn-wiring.jpg, any reason I shouldn't do this myself?
4. He was going to plow the wire in. I was thinking 3' deep and in conduit. Is he right?
Thanks,
- for #2 $1400
- for 2/0 $1900
Thanks,
