Another Drive Controller dead
   / Another Drive Controller dead #1
JACIII1
Lexington, ky
JOhn Deere 4310
Have replaced 3 drive controllers for failure. Each time thinking I found the problem.
All failures come with no self check error light sequence and no error codes. ie not LED indication whatsoever. Tractor does not move or report errors.
1) failed - original. Attributed to age (wear) 2002 model tractor.
2) failed 13 months later - JD Dealer advised rebuild alternator and replace diode. Suspected some reverse polarity current flow.
3) failed 6 months later - no code light or self check light. Got some output with vom from light wires indicating a very weak "sensor supply voltage".
Am at my wit's end with this thing. Have done the usual searches here and other tractor sites.
Any help or suggested avenues (up to and including "trade it off!" are appreciated.
Thanks,
Jim
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
