David Wayne
Last spring I ran a tile up a hillside through an area where there is a spring with water coming to the surface. It dried up for a few months, then water came back and runs down the hill about 100'. Today I dug the wet spot back up and found my tile. I cut it in two expecting to find it full of sand but it was open and took all the water from the hole and all that kept coming in. this one area, about 10'-15' long is sand, silt ,& gravel, looks like bags of Quikrete. The stuff has sealed off the slots in the tile. I am likely going to have to re-lay it and back fill with #4 stone. Should I also put a drain sock on the tile? Or is there a better solution? The sandy area is under about a foot of regular dirt & has the consistency of quiksand I will try to get a pic of it tomorrow or monday. Thanks
