Another coolant question - 5525
   / Another coolant question - 5525 #1
WouldWerker
Hi guys,
The other day my 5525 leaked some coolant on the shop floor (about a 4" puddle). I think it may have been a loose hose connection (which I tightened). But the thing that puzzles and concerns me is that when I ran her to check it out, she doesn't seem to warm up. The temp gauge never rose after idling at 1200 rpm for about 20 minutes; and I didn't see signs that that the thermostat was opening (no rushing water in the radiator). Outside temp was in the low 50s. No more leaks either. Is this normal or do I have a bad thermostat?
Chris
   / Another coolant question - 5525 #2
Seems to be a common thing with the Mahindras built in India. Have you worked it yet? Does the temp go up at all while in use?
Yes and yes... I have several times used it for extended periods (>2 hrs) pulling a shredder at 1900 rpm. The temp goes up some, but not alot.
   / Another coolant question - 5525 #4
I'm sure as you work it harder the temp will go higher. I changed the thermostat on my 7520 and it made no difference. When I work it hard, the temp goes up, a lot. :(
Thanks Brian,
I spoke with the Mahindra mechanic today and he basically said what you are saying... the cooling jackets on these engines are very big, and it takes alot of work to get 'em hot.
2022 Iron Craft 10' 3pt. Rotary Mower (A50774)
2022 Iron Craft...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
Radio Tower Antenna (A47384)
Radio Tower...
BUYERS PREMIUM & PAYMENT TERMS (A52576)
BUYERS PREMIUM &...
