another basic hyd question
   / another basic hyd question #1
brusew86
cherry velley, NY
NH TC45
say I have a PTO pump kit for a backhoe, where is the relief valve located? in the pump? in the valve? do gear pumps have a relief valve built in typically? the reason I ask is because I am building a PTO pump kit for woods BH 9000 and I'm wondering if I need a relief valve. the hoe has a relief valve in the valves set for 2400 is that all I need? Thanks!
the pumps I'm looking at are in the 3000 range. The typical tractor PTO pumps as you say are 2250 which isn't quite enough pressure for my application as the hoe takes 2400. I just wasn't sure if the relief on the hoes valves could be the sole relief. I thought it may be just a fine tune the pressure in case it's fed off a hydraulic source thats set a bit higher than 2400
   / another basic hyd question #4
You can adjust most any valve relief usually up to 3000 psi.
You can also gear up the rpm of the PTO output to meet the rpm requirement of a 3000 psi hyd gear pump.
Some tractors have more than one PTO speed.
Just for instance. if you need 10 GPM at 3000 psi, that would take about 21 HP to drive that pump.
A tractor with no attachments will usually have one relief and it is in the 3pt system.
If you add the FEL, the FEL valve is usually first in series and becomes the master relief.
If the BH is using the tractor hyd, you should set the BH relief to the tractor relief setting.
IH 470 Disk (A50515)
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
