Another 50-hour service
   / Another 50-hour service #1
Wheeldog
NW CT
Kubota B2410HSD
Just completed the 50-hour service on my B2410 tonight. Nothing much new here, just thought I'd be a good TBN'er and report in. Besides, it keeps me away from the TV news for a few minutes.
Engine oil and filter were pretty easy, filter and drain plug are more accessible than on either of the vehicles I maintain. Looks like the fill capacity is 3.6-3.7 qts. with the filter change. Right before the change I had noticed that the oil light would stay on momentarily after I started the engine (maybe a second or so). After the change the light now goes out immediately again. This kind of surprises me, but I had let the oil get down about 1/3 quart, so maybe the level did it.
The hydraulic fluid took a little longer, but I went pretty slowly. Took out the four drain plugs (did the center rear one first). All the plugs were pretty easy to get at. I then removed the strainer and the two filters. The strainer had a little ring of metal shavings/slivers near the hex head end, so I cleaned those off. They looked more like leftovers from machining instead of wear products but I don't know for sure. I put the strainer and suction line back, put on the new filters, and filled it up with new fluid.
Checked the tire lug nut torque and checked the air filter too, but everything was in order. Also lubed the grease fittings.
All in all this wasn't too tough a job to perform. I didn't have any problems with different filter part numbers or screwy sizes, so I was happy about that.
If anybody is getting ready to do this, the wrench/socket sizes are:
- Engine oil drain plug 19 mm (3/4-inch should work too)
- Transmission drain plugs 17 mm (3) and 14 mm (1)
- Transmission strainer hex 26 mm
I think the transmission info applies to a B7500 as well.
Rob
   / Another 50-hour service #2
Thanks for the timely post Wheeldog. My "dealer" is jacking me around on the 50 hour maintenance, so it looks like I'll be doing it myself shortly. I'll print out your comments and keep them handy. Did you replace the hydraulic filter?? I noticed the schedule just says to replace the fluid.
Kevin
Kevin,
I did change both the hydraulic filters as well as the fluid. Couldn't see not changing them as long as I had the fluid drained anyway. If you need any of the filter part numbers, let me know.
I'm not sure how much vehicle maintenance you do, but I would not call it a tough job. Very much akin to an engine oil & filter change or differential/transmission fluid change on a passenger car, only the access is easier (on the tractor).
Rob
   / Another 50-hour service #4
Rob,
Maybe you can confirm the following for me:
Oil filter = 70000-15241
Hydraulic filter = 66021-36060
Thanks,
Kevin
Kevin,
Engine Oil Filter: 15241-32099 ($11.95)
Hydraulic Fluid Filter (1): 66021-36060 ($5.34)
Hydraulic Fluid Filter (2): 67955-37710 ($13.19)
This is what my dealer sold me. The physical size was the same as the original filters at least. I've seen another post where somebody confirmed the two hydraulic filter p/n's, so I'm pretty confident that they're right. I guess you'll have to check with your dealer and see what they would sell you for parts. By the way, I found the prices at my dealer to be only slightly higher than on one of the internet sites for the filters, and I'd just as soon support the dealer if I can anyway so I went ahead and bought them there. (The prices are what I paid).
Good luck.
Rob
<P ID="edit"><FONT SIZE=-1>Edited by Wheeldog on 09/13/01 02:57 PM (server time).</FONT></P>
   / Another 50-hour service #6
Thanks for the info Rob. I'll let you know the parts I end up with /w3tcompact/icons/smile.gif.
Kevin
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
