Another 254 PTO Clutch problem...
   / Another 254 PTO Clutch problem... #1
PartTimeFarm
Hi, I've got a 254 pto clutch that won't stop the PTO so it grinds. I'll apologize in advance for the long post but I've tried quite a bit already... Last summer I had to do the bell housing gasket replacement. That went well and put everything back together and all worked with no issues. Over the winter, PTO started to grind when engaging and thought it was probably due to clutch wearing in after being taken off for bell housing fix and kicked myself for not replacing clutch at the same time as that. Read up on clutch adjustment procedure and tried that no luck so ordered full replacement clutch pack and PTO disk. Split tractor and installed new clutch with pto friction disk pointed the right way and adjusted gaps to specs, 2.5 mm for lever at throw out bearing and 1.2 mm for PTO adjustment nut. Started tractor and same issue with new clutch. Split tractor again and verified roll pins in the clutch pedal and the yoke are all ok, no slippage and a wire passes cleanly through each. Performed various adjustments with the stop bolt and adjustment rod using information on the many posts on here (all great information and very helpful). I've been able to make it better but there is still a small grind when engaging the PTO. Anything else I may have overlooked?
The one thing I would like to confirm is the release lever (part #15 in my diagram) to the throw out bearing (TOB). I've made the gap 2.5 mm as per spec, but the arm (all 3 actually) has some "slop" in it, meaning that when adjusting to the TOB I push the arm towards the front of the tractor so all the slop is out and then make the gap from there. The old clutch that I took off has this as well and based on how this is put together it seems like it would be normal but wanted to verify with others who have more experience.
Thanks in advance for any help.
   / Another 254 PTO Clutch problem... #2
Sorry to butt in but where did you get a clutch alignment tool? I'm in the process of tearing mine apart and haven't been able to source this tool yet anywhere.
How hard was it to unhook the front driveshaft? Thanks for any help.
My PTO won't disengage either. I tried tightening the gap with no luck and now my main clutch is starting to slip so I'm tearing it apart. In regards to your slop you mentioned in the clutch arms I read there is a little bushing that wears and can give that slop you are talking about.
I purchased a new clutch assembly from Affordable Tractor the alignment tool comes with it. I think they also sell them separately.
There should not be any wear on the bushings, its a new clutch.
The drive shaft is not too bad, the end closest to the back of the tractor is the one that slides back. The rubber boot can hang up but try a few times and you will get it. There are 6 ball bearings on each end that will fall out. Put a towel under each end when you remove the shaft to keep them from rolling away.
   / Another 254 PTO Clutch problem... #4
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
RYOBI 18V BRUSHLESS ELECTRIC 16" PUSH MOWER (A51248)
RYOBI 18V...
JOHN DEERE LOT IDENTIFIER 154 (A53084)
JOHN DEERE LOT...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
2020 COLOMBO TM LOT IDENTIFIER 202 (A53084)
2020 COLOMBO TM...
