Box Scraper Angling a Box Blade
   / Angling a Box Blade #1
Texas Dodge
Nursery, Texas
Kubota L3400 4WD
What is the correct way to angle your box blade to crown a driveway if you do not have a hydraulic top link? I don't want to bend my top link again.
Thanks.:D
blagg said:
If you mean left to right, I use my adjustable link to my lower 3ph arm.
Yes that is what I am asking. How many full turns is sufficient?
   / Angling a Box Blade #4
Depends on how many degrees of crown you want.
Set your blade on a flat surface.. like a driveway, now lift it so that it is 1/4" off the drive.. now adjust the hand crank to achieve the angle you want to use. Individual adjustment will vary by machine.
soundguy
soundguy
Ok thanks I'll try that.
Thanks for the help guys. Angling the BB worked great. Now I have the driveway sloped to the sides so the water will run off.:D
   / Angling a Box Blade #8
Makes one heck of a nice V shaped ditch also. Could not do without my BB.
   / Angling a Box Blade #9
Next to a FEL.. I consider a BB as the swiss army knife of tractor implements.
soundguy
   / Angling a Box Blade #10
I recently used mine this way. It was in some grassy clay soil and wouldn't dig much. I dropped 2 scrapers down on that side and it dug and cleaned out the ditch nicely.
FORD 2000 TRACTOR (A51243)
FORD 2000 TRACTOR...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
2009 Ford F250 Super Duty (A50515)
2009 Ford F250...
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
