angle gear drive
   / angle gear drive #1
joes_427_vette
Veteran Member
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
Does anyone know where I can buy an angle gear drive that is 1 to 3 ratio. Most I have seen are 1 to 1. I bought a flail mower and need the added speed for a nice clean cut. This should be able to adapt to a tractor pto. Thanks jr
   / angle gear drive #2
Not something I would do with a flail mower. /forums/images/graemlins/tongue.gif
But, wish you good luck. Don't think I would expect a better cut just by increasing the rpm 3 fold, although it would chop up the material into finer pieces, and may throw things a bit further. Might even make juice out of the grass. /forums/images/graemlins/wink.gif
   / angle gear drive
By using a 1 to 1 box and belt gearing for a final 2 to 1 ratio it turns slower than the orig setup. In tall grass ( 6 inches or more ) it tears rather than cut the weeds / grass cleanly. It had a 3 to 1 aluminum case box that went bad after the oil was not checked in several seasons of operation. @ 550 pto speed 3 to 1 only equates to 1650 rpm..... which is not super high. I have checked several vendors with no luck. I may have to slip some type of transmission in the drive line.
   / angle gear drive #4
Try surplus shop ( www.surplusshop.com ????I think.. ) something like that anyway..
Soundguy
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2017 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2015 CHEVROLET CAPRICE POLICE CAR (A51222)
2015 CHEVROLET...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
