Amsoil???????????
   / Amsoil??????????? #1
ericbx1500
Michigan
BX2380, scotts 48
I want to switch to amsoil for my bx. Is this the oil I want to use from amsoil...15W-40 Heavy Duty Diesel and Marine Oil
/forums/images/graemlins/confused.gif
   / Amsoil??????????? #2
No, that's not the oil you should use. HDD Series 3000 5w-30 or PCO 15w-40. In Michigan, I'd use the 5w-30.
   / Amsoil???????????
Thanks for the reply but whats wrong with 15w40 grade? Thats whats in the tractor now /forums/images/graemlins/confused.gif
   / Amsoil??????????? #4
I use the 15W-40 diesel/marine oil in my mom's GMC pickup and it has been perfectly fine even in the winter. Being a "real" synthetic, it doesn't have any issues with thickening up in the cold, so I wouldn't worry about that. Having said that, however, check your owner's manual for their recommended viscosity. My JD990, as with many newer diesels, recommends a thinner oil and I use the series 3000 5W-30 in it. I think the general trend these days is towards using thinner oils.
Contrary to popular opinion, I personally don't believe you need a thick oil to protect a diesel's internals against combustion shock loads *IF* the engine has been properly designed to use a thinner oil (appropriate clearances, high flow rates, etc.). I think many newer engines are going that way. Besides, a good synthetic has much better film strength than an equivalent weight dino oil anyway, so the 5W-30 probably resists being "pounded out" of bearings as good as a 15W-40 dino oil.
Another thing to consider is that if your engine has been designed for a thinner oil, putting 15W-40 in it may actually be detrimental in that it may not achieve the flow rates that the engine designers had intended. Again, the best thing to do is use something close to what the manual recommends.
/forums/images/graemlins/laugh.gif
   / Amsoil??????????? #5
The advice that is always correct is to use any oil that meets the requirements (API rating and grade) recommended in your operator's manual.
   / Amsoil??????????? #6
</font><font color="blue" class="small">( The advice that is always correct is to use any oil that meets the requirements (API rating and grade) recommended in your operator's manual. )</font>
Agreed 100%. The designers of the engines never specify BRAND....they just specify "API rating and grade". Syn oil...Dino oil..or even "gorilla snot"...it SHOULD be the proper rating and grade
   / Amsoil??????????? #7
How many hrs. a year do you log? If around 100 run the HDD Series 3000 and change it annually. You'll be draining out oil that is almost new if you do it this way. Check my thread on my UOA using Amsoil 10w40. I basically wasted my money by not going 2 years on this fill.
   / Amsoil??????????? #8
The BX calls for 10-30 or 10- 40. I run the heavy duty 15- 40 Amsoil in my BX 22. Although I may look for a 10 -40 just to meet specs. I believe the proper weight and viscosity is important to avoid pre mature wear in those tight spots /forums/images/graemlins/smile.gif
   / Amsoil??????????? #10
<font color="blue"> Anybody else tried this yet?</font>
Yes, fine oil.
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
1983 Case 580D (A47477)
1983 Case 580D...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
