vaj
my jd4110 maunal calls for 15w40 , 5w30 or 10w30. The manual's chart shows 15w40 for temps -4F to 120F and 5w30 for -15F to 110F. 5w30 would be my dino oil choice for here in NYsince it may get quite cold but not really over 100 degrees. The 15w amsoil costs $6.10qt and their 5w30 $9.40qt. I am leaning to the 15w. My understanding is these true synthetics have extended temp ranges. Am I right to assume the amsoil 15w40 diesel and marine will greatly exceed the temps the jd 15w40 dino oil is rated for?
ALso the manual calls for API class SG or higher. I do not see this class rating for either of the two amsoil oils. It just says recommended for diesel engines--
"AMSOIL Synthetic 5W-30 Heavy Duty Diesel Oil is recommended for diesel engines and other applications requiring any of the listed worldwide specifications and gasoline engines requiring API SL, SJ, SH . . . or ACEA A3."
