Amsoil Spy Grease
   / Amsoil Spy Grease #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
I would like to add some NLGI 00 grease to my Rhino cutter gearbox due to the fact that the front seal now leaks after I got a willow limb wrapped up in the yoke.
Unfortunately it appears that I would have to buy a 5-gallon bucket of the Amsoil Spy Grease, which would be about a 100 year supply.
Any idea where I can get similar grease like this retail, and how to you get it in the gearbox? I have a grease gun with a nipple - can you get it in a regular grease tube, or is it too fluid for that?
   / Amsoil Spy Grease #2
Why not just replace the seal?, and then run the gear lube recomended. Remember, the oil in there is as much for lubrication as it is for heat sink / cooling properties... that is why most final drives run in oil not grease.. and why steering boxes -can- run in grease..less heat due to less movement.
Soundguy
   / Amsoil Spy Grease #3
nope i've tried 5gal. seems to be the norm. check caterpillar and jd for smaller sizes not looked yet.
Actualy many suppliers use 00 grease it's becoming more of a std. practice to keep from repeated seal replacement.
If you can find it it works good. many people i've heard of putting a grease fitting on the oil fill vent and filling it full of std grease..
   / Amsoil Spy Grease
Soundguy, I talked to a Rhino service rep and he stated that my gearbox was shipped with 00 in it. I guess it can't go anywhere, but I added some 80-90 to it a while back and now the seal leaks a little. He said its OK to mix, but I wonder if my addition of lighter oil has made the 00 that was in there a lot thinner.
   / Amsoil Spy Grease #5
I'm sure the average viscosity of the oil/grease mixture is somewhere between the original values of the oil, and the grease... so yes.. plainly.
Soundguy
   / Amsoil Spy Grease #6
My NH dealer has the grease in quarts,I think it had a NH label . dass
2011 CHEVROLET G3 BOX TRUCK (A50459)
2011 CHEVROLET G3...
UNUSED LANDHONOR 5400# RATCHETS & G70 CHAINS (A50460)
UNUSED LANDHONOR...
Gator Utility Cart (A49346)
Gator Utility Cart...
2015 John Deere 344K Wheel Loader (A50490)
2015 John Deere...
1986 Toyota Pickup Pickup Truck, VIN # JT4RN67S8G5041038 (A48836)
1986 Toyota Pickup...
New Holland 55 Pull Type Rake (A48837)
New Holland 55...
