Amsoil or Permatran
   / Amsoil or Permatran #1
billclarketbn
Altamont, NY
Massey GC2300
Is the new 821 XL Permatran a synthetic hydraulic oil? Is it really any better than NAPA's best (listed as equal to Permatran on their jug) and adding some Lucas booster?
   / Amsoil or Permatran #2
Google is your friend. Check it out and tell us what you learned... ;>) Dutchy
   / Amsoil or Permatran #3
depends on the end use and what you consider good and what you consider cheap junk. Any triple 3 fluid is basically junk.
I really do not trust Google much and have not a clue what a triple 3 fluid is.
My hydraulic fluid weeps slightly from the Nimco control. Did not do this until I replaced the existing fluid with Napa (which says compatible with Permatran). Lucas product ads sound good and some posts I have seen sound good. Thought about Amsoil fluid or the new 821 XL. But, the current fluid only has about 50 hour on it. Hence, thinking about Lucas product. Weeping may just be the high dollar Nimco not doing its job.
I am 75 and do not get around well, so things are best done once and done right. My dealer is next to useless - only interested in heavy equipment sales. Not is subcompact service. Tried to get him to come out and service or even come and get it and take it for service - no interest! So I have to do everything myself. No family except wife (she does help a lot). Even thought about selling and buying a new one - but am a little hard put to replace a tractor with only 440 hours on it.
It hauls yard debris, trash cans, and what ever lifting we need done. Also plows snow in the winter. Lives in a heated garage. Basically, a very easy life.
Now you know why I ask the experts. I really would appreciate some advice.
   / Amsoil or Permatran #5
Looks like the 821 Permatran is a synthetic and if it has the XL designation it means that it is longer life version of the basic 821 Permatran.
I use AMSOIL Tractor/Hydraulic fluid in my Kioti CK30HST and it's coming up to 300 hours on the oil. It looks good, so I'll change the filters soon and possibly take UOA sample to have it tested. My tractor is about 10 minutes from my house and when I start it to blow snow I hardly need to warm the tractor up because the hydraulics work smooth as if it's summer temps. I also use AMSOIL in the engine to help the cold starts. It can get to -30C quite easily here in Ontario Canada.
Here is a link if you wish to check it out. Pricey here in Canada, but to me I'm very happy with it. A bonus for you guys it's made in 'Merica too. AMSOIL Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-3
Dutchy
   / Amsoil or Permatran #6
The GC2300 takes under 4 gallons for a full fluid change, hydro and front axle (same oil). I would avoid the 821XL, there are better fluids. Kubota SUDT2 is among the best affordably priced fluids that is widely available. Amsoil is best for extreme conditions, but also has a hefty price tag. "Compatible With" or "Meets Standard" means absolutely nothing when dealing with most economy brand tractor fluids.
   / Amsoil or Permatran #7
I would suggest that the front axle oil be changed out to a gear lube such as 75w90 or similar at the 50 hour service. Typically the front axle would come with hydraulic lube from the factory, less chance of a mix-up during the factory build, with the recommendation of a gear lube being installed after break-in. You don't want a thin lube in your 4x4 front axle while digging, pushing or transporting heavy loads etc. Dutchy
   / Amsoil or Permatran #8
Bill,
If it was my tractor I’d consider 2 options. First, leave it alone. The weeping might continue if you change to a more expensive fluid. The NAPA oil you used is formulated by one of the major oil companies and if it says it meets Permatran specs, it meets Permatran specs. I personally avoid Lucas products and would not add their additive. Lucas spends a lot of money on advertising and do some good in sponsoring races but I don’t think their products are very good.
The other option, for your piece of mind, is to change to the Amsoil tractor hydraulic fluid. It will be expensive but I don't think you can find a significantly better product. You will not have to change it again. Your valve may continue to weep no matter what oil you use. I would just consider that it is a tractor and a little weeping is going to happen as it piles up the hours.
   / Amsoil or Permatran #9
Saved this from and old TBN thread.
Authenticated Program - TractorLife
Good reading material and possible choices for you to select.
I was about to make a mistake based on many post here and buy the 303 fluid. Glad I did not.
I find it difficult to believe a fluid 'caused' a leak.
Fluids leak for many reasons and more are due to changes in mechanical integrity.
Do you have a local heavy equipment repair shop near you?
I've spoken with one here and will service my tractor when it is out of warranty. So they do exist, so for your consideration.
Regards....
The plan: Going to add the Lucas and see what happens. If that does not do the job, then in the spring I will get the valve professionally rebuilt and put in Amsoil. Also going to add JD dye, then I can see what is in the glass easier. In the engine, I use Rotella T4 15W-40. Thanks for the replies - good advice and appreciated.
Bradley Electric Smoker and Cover (A51573)
Bradley Electric...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
New Wolverine Push Blade (A53002)
New Wolverine Push...
20ft Driveway Gate (A51573)
20ft Driveway Gate...
