Amsoil Hydro fluid
   / Amsoil Hydro fluid #1
Nuru
Elite Member
I have read the info on the Amsoil site, i have had a 5 gallon
container quoted for approx. $90 bucks for my 4100. Is this oil pretty good or as good as it is advertising or what? I am, considering purchasing their product called "Synthetic Tractor Hydraulic/Transmission Fluid, C-3, C-4"
   / Amsoil Hydro fluid #2
I swithed all of the fluids in my l3000dt to amsoil synthetic. It runs great. This is not a hydro unit so we don't have apples to apples here. I have however used the amsoil stuff in the ztr mower and it is just fine. I also switched the f350 and the suburben over and here there was definately an improvement. Especially in the transmission. I think that redline is the top synthetic, then amsoil, and mobil. Don't take this as gospel, just one man's opinion. See how this compares to other responses.
Good luck, Rich.
   / Amsoil Hydro fluid #3
I am running Amsoil in my engine and hydro circuit. I am using 5W-30 HDD Series 3000 in the engine and the synthetic Tractor Hydraulic/Transmission Fluid (SAE30) in my hydrostatic drive and front axle.
I also used these same oils in my 96 JD 955 with NO whining of the hydro drive in weather down to -10 deg F. I changed my 4700 over to synthetic at 25 hours.
rja, thanks, this is good info.
Nuru
sniezur; sounds you have completely answred my question. The two oils that you are using are the same ones that I am contemplating.
Nuru
   / Amsoil Hydro fluid #6
Those are also the same products I used in my L4310HST. I'll be using the SAE 5W30 HD Diesel oil in the EF-5, but the hydraulic oil will have to be the Amsoil AWI, because it requires a higher viscosity grade.
Thanks for the info MChalkley
Nuru
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2011 John Deere 120D (A47477)
2011 John Deere...
Chevrolet C8500 Flat Bed with a Moffet Kit (A55218)
Chevrolet C8500...
HIGH END TRICYCLE SCOOTER (A53843)
HIGH END TRICYCLE...
